Go to Post wow!! Andy Baker really is a pig farmer!! and all this time i thought that paul copioli was stereotyping! - RogerR [more]
Unread 05-10-2010, 15:36
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
Re: pic: Belt Drive Chassis
Originally Posted by JB987 View Post
One thing to consider regarding use of a single belt per side...if you do have a very rare belt failure your bot will basically be dead on the field while use of two belts per side still allows decent mobility should one belt fail on a given side. Good for you to consider using a belt though...987 switched 3 years ago to belts and loves them.
As you guys have some experience with these belt drives...
How does the belt drive handle high torque situations, such as a pushing contest vs. another robot? Can it handle a high-torque transmission setup?
Also, assuming the belt is inside rectangular tubing, how easy/difficult would it be to change a belt if you do have that rare belt failure? I can see pulling out the axles of the end wheels to wrap a belt around the pulley relatively easy, but the axle of your center wheel is also the output shaft of your transmission--seems very time consuming to change if you're in a playoff situation.
I think I too would go with 2 belts on each side--you would guarantee a solid 180-degree wrap on each pulley, plus the redundancy of multiple belts.
Belt drive esisso Motors 7 22-01-2008 23:19
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
