Go to Post If I run into some of your team's student coaches/drivers on the field of battle someday, I still might ask 'em what they're doing after high school. :) - Ken Patton [more]
Unread 06-10-2010, 09:24
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Broken Output Shaft
Those grooves cut into the shaft are a HUGE no-no is shaft design. It probably didn't help that there was a hole drilled through the middle, but those grooves are big stress risers where the shaft is experiencing the most stress.
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
