Go to Post Kids should already be motivated to build the best robot they can, and learn as much as they can. They shouldn't need extra incentives. - Matt382 [more]
  #31   Spotlight this post!
Unread 04-10-2010, 09:30
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: pic: Reverse Drive
Originally Posted by RyanCahoon View Post
Side note: Another way to fix this that's always worked for me is wiring one of the motors backwards. (wire the Victor's output backwards, not the input)
That could give you problems with a strict robot inspector. Wiring must comply with the color coding rules. Yes, you can tape over the entire motor lead, but this only simplifies your code, it doesn't eliminate bias. As long as the motors are oriented 180 degrees apart one has to travel in the opposite direction to the other to move in the same relative direction.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
  #32   Spotlight this post!
Unread 04-10-2010, 09:36
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It should only give you trouble with an uninformed robot inspector. <R48> specifically allows for different coloring schemes on the output of a speed controller because the speed controller does not output constant polarity.
  #33   Spotlight this post!
Unread 04-10-2010, 09:55
Jared Russell's Avatar
Taking a year (mostly) off
Reminds me of this: http://www.chiefdelphi.com/media/photos/17269
The drill motors we used until 2005 had horrendous bias (around 10% if I recall correctly), so some teams came up with ways to correct for it mechanically.
  #34   Spotlight this post!
Unread 04-10-2010, 10:25
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by joeweber View Post
...dealing with gyros, rotation sensors, accelerometers and a camera...
A quadrature encoder (rotation sensor) should be all you need. As long as both sides are going the same speed, it will not drift. You do not need to further compensate with other sensors.
We have a small team with one programer that has other things to do durring build season.
Myself and a programming mentor (who is also very busy, being the lead mentor) are the only current programmers on team 33. I wrote all of the code myself, and there is quite a bit of it for our current robot, especially in the arm.
If you would like my autonomous drive straight block, PM me and I will send it to you (apparently I can't post attachments in this thread).
Kettering Motorsports
  #35   Spotlight this post!
Unread 06-10-2010, 11:26
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Interesting conversation. Please let us know if your mechanical approach solves the problem. I suspect the extra gear will on one side of the robot will cause more loss due to friction than the perceived motor bias issue.
  #36   Spotlight this post!
Unread 06-10-2010, 18:41
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
I believe a good rule is that you retain 85-95% of power through each spur gear stage?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #37   Spotlight this post!
Unread 06-10-2010, 18:48
ajd ajd is offline
FRC #3238
ajd will become famous soon enough
never mind
  #38   Spotlight this post!
Unread 06-10-2010, 19:29
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
For our team, driving straight was not an issue of motor bias, but a Jaguar issue. We were giving our Jaguar on one side a value of -1, and it would only output -.9 (I am not sure the exact number, so feel free to correct me.). We this causes a much more noticable difference than any motor bias did.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
  #39   Spotlight this post!
Unread 06-10-2010, 21:03
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
I hope this is not straying too much but no one has mentioned the wire length. I made the mistake this year of having the wires to the wheel motors all different lengths. We used mecanum wheels and a joystick control, no encoder, and I believe the gyro was only used to orient the control before a match. While we seemed to go straight in autonomous it is hard to drive straight.
Does the wire length really make much difference, enough to be the OP's issue?
  #40   Spotlight this post!
Unread 06-10-2010, 21:57
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
What gauge was the wire and what was the difference in length?
  #41   Spotlight this post!
Unread 06-10-2010, 22:12
Rookie Year: 1997
A rule of thumb is that 10 awg wire drops .1 volts over 1 foot at 100 amps. Most drive trains don't draw 100 amps for normal driving. If you assume 40 amps and a 1 foot different, that's .04 volts dropped or 0.3% of 12 volts. It would be worse if smaller wire is used (eg 12 awg), there is a longer length mismatch, or you have a particularly inefficient or high current drivetrain.
  #42   Spotlight this post!
Unread 07-10-2010, 11:41
J@GMFlint's Avatar
J@GMFlint J@GMFlint is offline
FRC #1243 (Dragons)
J@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond repute
Joe- The gearbox revision looks pretty cool! But as you've no doubt read here, there are a lot of ways to approach the bias issue. I'll share our typical method here.
Every year as SOP we tach. all of our CIM's fwd & bwd -straight off supply- before assembling them into a drive unit, I don't think we've ever had one with same RPM in both directions. We then match the motors by RPM, or sets as best as we can. There are some differences that do level out, and as someone noted earlier, older motors tend to show more variation -based on our data anyways.
Once the robot is fully assembled, we again use a tach. & check for friction. Then after some intitial driving (which most always has some bias and the drivers complain) we adjust the output commands (in software) for the fwd running motor down until free speeds are nearly equal. Then live test again on the surface to confirm or adjust further (then the drivers are happy, and lose an excuse for not driving straight! ). From there we may again tune, but it's usually close enough. We have only installed encoders when more precision was required, ie. placing, errr trying to place, tubes in 2007, or runnning laps in 2008 in auton.
This year, we detuned the forward AM-GEN1 side a straight 4% throughout the scale all the time. For what we were doing, this worked well enough and the robot was pretty repeatable.
Closed-loop (encoders) when practical and within your resource capabilities are almost (IMO as a robotics engineer) always a better method if you can control slippage on the carpet or surface. Not only that, if you have a good control loop, it can adjust and compensate for a multitude of sins and still keep your robot going where you want to. Keep in mind, that doing this is not always as easy as it sounds and can take some precious time away from things like practicing playing the game in teleop.
14th Season Leading and Mentoring Great Students!!
FINALIST 2014 GLBRD- Thanks 5281 & 2145
Qtr-Finalist 2014 Bedford District
Qtr-Finalist 2014 Kettering District- (Which way was the robot s'posed to be facing...?!)
FINALIST 2011 Kettering District- God work 494 & 1684- great elim. debut Chimera's!
WINNER! 2010 West Michigan District- Awesome job 3357 & 2054!
WINNER! 2004 West Michigan Regional
2004 Rookie All-Star & Highest Rookie Seed Pittsburgh Rgnl; Rookie Inspiration & Highest Rookie Seed West Michigan Rgnl (3rd)
2007 Semi-Finalist MWR
2008 Finalist MWR - Thanks 111 & 1504 Judges Award MWR
2010 Semi-Finalist Kettering District - Thanks 1, & our friends 2337
reverse hurdle. Stillen General Forum 5 06-02-2008 19:59
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Reverse Robotics !!!!!!!!!! dan 322 General Forum 42 25-04-2004 00:44
Chiaphua in reverse?? Christina Motors 2 09-01-2002 08:40
