Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 06-10-2010, 15:10
Re: pic: Broken Output Shaft
I'm certain the large slot for the dog shifter was more of a stress riser than the snap ring grooves.
And Chris, not that most teams use snap rings on the extremes of the shaft, where there is no load being applied; it's less common to see them between loads like this.
Originally Posted by EricVanWyk View Post
Could someone with some MechSkills post an FMEA of the stress in a design like this vs a key-way?
Thanks!!
It wouldn't be a universally accurate demonstration.
The location of all such features and loads would have a large effect on the result.
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
