Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 09-10-2010, 16:00
Sh1ine Sh1ine is offline
FRC #2791
Re: pic: Belt Drive Chassis Take 2
Originally Posted by Sh1ine View Post
There really is no reason. I starting off thinking that it would be easier to have one belt, and get the system in the tube. Now after reading everyones thoughts I think it is going to be harder. Did you have a spring tensioner in your system? Did you use steel pulleys or were you able to find Aluminum one? I can only find GT2 steel pulleys.
I was just reading the thread on your bot, and learned about your tensioner. Very ingenuous. Did you end up using a similar design for the game? How did the belts hold up over time?
pic: Belt Drive Chassis Sh1ine Extra Discussion 11 07-10-2010 07:11
pic: Schreiber Take on West Coast Drive Andrew Schreiber Extra Discussion 69 23-08-2010 00:36
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
