Go to Post Seasons are often made or broken in the first week of build season. 1114 wouldn't be repeatedly giving their strategic design seminar if it wasn't that important. - Knufire [more]
Unread 10-10-2010, 15:22
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: pic: Broken Output Shaft
You have a large aspect ratio in this problem - long shaft and short, small keyway.
Make certain you Add-in SolidWorks Simulation under the Tools menu. SimulationXpress will only give you a simple approximation. You need full SolidWorks Simulation.
You will need to adjust the mesh to be finer around the keyway.
Marie
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
roll pin into output shaft m1k3 Kit & Additional Hardware 18 15-01-2008 16:18
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
