Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 21-10-2010, 16:09
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Stress plots related to broken output shaft
Interesting plot and good to know the ramifications of a mis-fitted snap ring. I'm curious to know if the stress loading is the same when a properly-sized snap ring is in place?
Edit: misunderstood your question. Adam got it.
I would imagine that cutting the groove even deeper into the shaft would only exacerbate the problem. The stresses would have an even greater discontinuity to work around.
I should be clear that this shaft is experiencing torsional loading.
pic: Broken Output Shaft Jon Jack Extra Discussion 19 15-11-2010 20:47
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
