Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 22-10-2010, 00:25
M. Mellott's Avatar
M. Mellott M. Mellott is online now
CAD God
AKA: Mike Mellott
Re: pic: Stress plots related to broken output shaft
One option that comes to mind might be to use a tool that has radii in the bottom corners (or completely rounded on the bottom and cut your groove a few thousandths deeper) rather that sharp points. Sharp edges are stress concentrators, so the blends might remove some of the stress points.
Now, one might say a completely rounded groove bottom might also take away too much of the vertical side walls of the groove and defeat the primary purpose--holding a snap ring and supporting an axial load...but some snap rings have rounded cross-sections, so...
pic: Broken Output Shaft Jon Jack Extra Discussion 19 15-11-2010 20:47
Gearbox Output Shaft Defect Nathan2974 General Forum 2 16-01-2010 10:26
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
