Thread Tools |
Rating:
Display Modes |
Re: pic: Revolution Swerve Demo Robot
Impressive! How well do the MA3 encoders work? We did a 2-2 swerve drive this past year and ended up using pots for feedback because the encoders we had (idk the model but they were magnetic) were not reliable enough to get the two sets of wheels pointed in the same direction. Clearly that isn't an issue with all four wheels chained together in this fashion, but I'm wondering if there are any noticeable issues with the angular accuracy with these encoders (I know they claim to be <.5 degrees, but that's what the ones we had said as well and there wound up being a difference of at least 15 degrees.)
Both sides would be off a bit pretty much all the time. When we tried debugging it in java we saw that the encoders would read equal values at angles that were visibly unequal. At times the wheels would seem fine and at other times they clearly were not our drive train would sometimes look like this (top view where "|" indicates the wheel direction):
| | | | and other times be like this: \ | \ | and when we switched them with the pots it worked fine. We were just interested in using encoders because pots are notorious for blowing out at the least convenient time possible .So to answer the question...not repeatable. |
You said in an earlier post you don't remember the model number of the encoders you tried. Is there anyone on your team who might remember?
How do you connect the sensor to your mechanical component? Could you be slipping? That's what it sounds like to me. We always use these. Quote:
We have one MA3 encoder on each steering axis.....the encoder is linked via helical beam coupling to a 1/4" shaft that is keyed to an idler sprocket. |
good luck with than macanum is easyer.
And we all know that because something is "easyer" it is better, right?
You've clearly put a lot of thought into the debate between a "macanum" drive and a coaxial swerve -- right? Perhaps you'd like to show us your pro/con list for each? Of course, this list includes only quantitative engineering based arguments, right? This is an engineering competition. Do some. -John |
I like these little systems. FIRST should take note of their flexibility and performance for the price.
Nice robot |
| pic: Revolution Swerve in Brilliant Gold | ajlapp | Extra Discussion | 18 | 05-12-2011 21:22 |
| pic: 221 Robotic Systems Swerve Demo Bot Steering Feedback | ajlapp | Extra Discussion | 16 | 02-09-2010 18:31 |
| pic: Wild Swerve Demo Chassis | ajlapp | Extra Discussion | 12 | 17-10-2009 08:09 |
| pic: Revolution Co-Axial Swerve Module - Team 221 LLC. | ajlapp | Extra Discussion | 10 | 31-08-2009 15:28 |
| pic: Robonauts '09 -- Revolution | Justin Ridley | Robot Showcase | 10 | 25-02-2009 21:53 |
