Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 14-11-2010, 00:08
maverickfan138's Avatar
maverickfan138 maverickfan138 is offline
Still hooked on FRC
AKA: Marc Antinossi
FRC #0573 (Mech Warriors)
maverickfan138 will become famous soon enoughmaverickfan138 will become famous soon enough
pic: Team 573's 2010 OCCRA robot
Unread 14-11-2010, 00:09
blackiceskier's Avatar
blackiceskier blackiceskier is offline
ziggy!!!
AKA: josh T
FTC #3041 (URSA MAJOR)
blackiceskier will become famous soon enoughblackiceskier will become famous soon enough
Send a message via AIM to blackiceskier
Re: pic: Team 573's 2010 OCCRA robot
This sounds similar to last years VEX game of Clean Sweep
Unread 14-11-2010, 09:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Except these robots are 38x28x40x115lb (120 if you use pneumatics, weights include battery).
573 is currently ranked 3rd out of 20 teams, however there are still more matches to play and the league drops the lowest 6 matches when determining final seeding order, so the order will change based on how bad/good your lowest matches are.
Kettering Motorsports
Unread 14-11-2010, 10:44
It looks like they have a pretty simple robot - a conveyor brings a few balls up to a simple flywheel? Simple tends to win these kind of events.
Does anyone have some kind of massive dumper that just flings a basket full of balls across the field?
Unread 14-11-2010, 11:37
apalrd's Avatar
More Torque!
VRC #3333
"simple"?
2 mechanisms (conveyor and shooter).
This is about as complex as is possible for an OCCRA robot. Some teams have 3 mechanisms. Anything more is too difficult to build (both build period and build in weight).
Most teams have a 4 wheel drive or 2 wheel with casters. A few have 6. Most teams don't have many powered mechanisms (we have 4 victors and 1 spike for our whole robot), but build something simple, practice, and go out and do what they do well.
All of the top robots (as of now) have a conveyor and a high-speed roller/wheel. Some collect and shoot on the same "front", some (like 573) collect on the "front" and shoot on the "other front".
We don't have quite as much raw power as we do in FIRST. We have 3 CIM motors and Toughboxes (Most teams use these to drive, and use the third CIM to shoot), plus two DeWalt drill motors (really useful, 3-speed, and they can have anti-backdrive pins if you leave them in). Most use these for conveyors or arms. A few drive with them. The rest are all small (under 60w) - Globe, seat, powered liftgate, wiper motors. In past years, we have had only 3 drill motors and no CIM's, so we are gradually getting more power.
We are also required to use 35 pitch chain only (no 25) because of the lack of precision in OCCRA robots, cannot weld, and cannot "precision-machine" (using a lathe, mill, or CNC machine). Most parts are made on a drill press and bandsaw.
Unread 14-11-2010, 15:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Sounds a lot like the 1519 and 3467 workshops and you'd be surprised what you can make with them! I think what Chris means to say is that it holds a few ball and a one wheeled shooter. Nothing fancy to store balls like a screw or hopper no turret or pitch settings on the shooter. It is very simple and yet can be so effective!
It looks really good for the limits you guys have when building!
1058 PVC Pirates 2016 - xxxx
Unread 14-11-2010, 20:18
Still hooked on FRC
AKA: Marc Antinossi
Chris: There aren't any catapult robots this year. A catapult did come up during our design sessions and was one of the last to be eliminated. A lot of the robots look like 67's robot for Lunacy.
A few more specs on our robot:
Drivetrain:
4 wheel drive
Each side powered by one CIM and Toughbox
Entire motor assembly slides along chassis rail for tensioning
8" wheels
Bricks are used for counterweights on the front of the chassis
Appendage:
CIM powers shooter wheels(ratio of 3:1)
Dewalt powers transport belt
Turnbuckles are used for tensioning on both the belt and chain(from Dewalt to belt)
Plexiglass arcs are used to funnel and center the ball before being sucked up
Other:
Our speed is around 8ft/sec
We can climb the bump
We have attained two clean sweeps(all balls on the other side of the field)
We used a similar design in last years OCCRA game, where we had to play basketball. We made a few modifications to increase the performance of our robot this year. We are very pleased with our performance this year and we can't wait until Saturday.
2010 - 2011: FRC 573 student
2012 and beyond: MTU student, watching FRC from afar
Unread 15-11-2010, 10:51
Another quick question: what's to stop a team from picking up every ball, driving up the bump, and just sitting on the opponent's side of the field until the match ends?
Unread 15-11-2010, 15:42
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
Robots are only allowed to hold 5 balls at a time where holding consists of the robot touching a ball while it is off the ground.
If you want to read the rulebook http://www.chiefdelphi.com/media/papers/2409
Unread 15-11-2010, 15:44
apalrd's Avatar
More Torque!
VRC #3333
One of the rules states that a robot may not carry more than 5 balls at one time.
573's 2010 Video Highlights maverickfan138 Robot Showcase 2 06-09-2010 11:23
pic: team #176 2010 robot kinghashbrown Extra Discussion 1 14-05-2010 10:59
pic: Team 2016 Robot 2010 ks_mumupsi Extra Discussion 12 01-03-2010 14:36
pic: Team 79's Robot 2010 JonellGregor Extra Discussion 8 24-02-2010 19:00
Team 573's Robot Jimmy General Forum 1 07-04-2003 19:30
