Re: How much Calculus?
After almost 30 years since my EE degree, I can't say I use Calculus much. But then again I was never a design engineer, I have always had positions where I supported existing product. These days I write training for a living.
But having said that, and noting that although I see the beauty in math and how it describes the physical world, knowing and understanding calculus was absolutely essential to my career. You see, in order to support a product (or write training about it) you must understand the design. And for that, you need to know calculus, otherwise you get lost pretty quick. Some advice I wish I had as a college freshman: If you don't understand it, or are struggling to keep up, ask for help. Sometimes you need to look beyond your professor (there may be a personality difference), but once you find someone who can explain it in a way YOU understand, it gets a LOT easier. |
And don't limit yourself to instructors... purposely seek out and develop friendships with other students in each class who are serious about doing well. Make learning the subject material part of your common interest. |
With middle school roboteers no Calc, lots of geometry. We engineers have decided that PI=3 for all calculations. In a 12' space the .14159 part isn't making any noticeable difference.
In my job, lots of basic math and a ton of stats (project manager). Most along the lines of "probability of meeting the deadline on Tuesday is none." After slogging though calc classes, I'd rather have the stat classes. Gary mentioned matrix math, I did a ton of that when hand crafting graphics routines in hand crafted Fortran and assembler. Cycle times were slow and you had to wring everything out of each instruction. The Winter Session Matrix Math class saved me in some tough situations. |
Jason |
Upper classmen can be a great resource. I was struggling for a whole quarter with some math for Physics. A guy a year ahead of me saw what I was struggling with and gave a very simple explanation of what was going on. It took about 15 minutes to go from failing to a C. I still wish I had talked to him before Finals week.
It's kind of hard to quote every single post that was put on this thread, but if it didn't take up too much space would. Thanks for all of your advice. For me, it's not that I wasn't necessarily scared of calculus, it's just that I came across another forum where many engineers said they did not use calc that much. So I tried the same question on CD and got more of an opposite response.
However, a common response that I got from both forums is just the knowledge of calculus and knowing the meanings behind problems can be just as helpful as a small calculation. BTW here is the link to the other forum if you are interested. |
I use calculus and differential equations on a very regular basis.
For a job like mine, the most important thing is to know how to set up a calculus problem or a differential equation. Therefore, having a very good knowledge of what an integral or derivative really means is of utmost importance, and I think that gets lost on a lot of people. If a problem is put in front of you and you can say, "what we need is X, which can be determined as the integral of f(x,t,etc.)" and write the equation, that's the big deal. From that point on, most of the time the actual integration is done numerically in the algorithm that we're designing. I summary, VERY MUCH of my job is setting up the correct equations so the algorithms can do the calculus in real-time. In that respect, I use a lot of calculus and differential equations on a daily basis. |
I taught Calculus for 10 years and used Calculus as a mechanical engineer in my work - but not all the time. I always used to tell my students that Calculus makes your other math skills stronger. When I was an engineering student, all I wanted to be was a design engineer. But engineering teaches you how to solve problems, not just the ones that are Calculus-based. You can solve customer problems, field engineering, support, marketing and social problems - sometimes Calculus doesn't stand out. It is just a tool to describe a problem.
Marie's tips - know - really know the unit circle with all its common values both in decimal and radical form, 30-60-90 degree, 45-45-90 degree and pythagorean triples - most common 3-4-5 but there are others 5-12-13, 8-15-17, 7-24-25. Most engineering text books has exercises that can be done without a calculator knowing these relationships and the ratio of sine, cosine, and tangent. Watch - really watch the minus sign. The most common error is caused by this little sign. I once had a professor take off 20 points in a differential equation exam question. I filled two blue books to answer the question - got the correct value - wrong sign. Lesson learned. Units, units and more units. It is a must - most dont use until the end of the problem but know your units and use them - watch radians and revolutions; they are not the same. Label all answer with units. You should feel as comfortable with inches as you are with SI. Most engineering schools use SI units in the world - we are global. Marie |
The best teacher I ever had was my high school chem AP teacher. He would constantly stress units to us saying his famous phrase: Quote:
-Brando |
| Ball Capacity? How Much is Too Much? And Can You Use It For A Strategical Advantage? | thefro526 | Rules/Strategy | 21 | 01-02-2009 02:56 |
| How much of a field? | StephLee | General Forum | 11 | 11-01-2007 23:48 |
| how much is too much on the DRILL MOTORS? | archiver | 2001 | 11 | 23-06-2002 23:53 |
| How Much? | purplehaze357 | Off-Season Events | 12 | 17-05-2002 16:04 |
