Go to Post Andy, you have daughters, would you buy them a Dave doll? - MissInformation [more]
Unread 17-11-2010, 20:06
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: pic: Soldering accidents...
we haven't killed a laptop yet, but we have had one team member use pipe solder to solder wires. Needless to say, it didn't go well and there was solder all over the table for weeks
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 18-11-2010, 07:37
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
For those of you just stopping by, there are different types of solders. The type referred to in the previous post does not contain flux. Without flux, the solder and the wires are dissimilar metals and have oxidation on the surfaces preventing the solder from adhering to the metals. In soldering pipe, an acid base flux is wiped on the surfaces before they are heated. In wire solder, the flux is internal to the solder wire. It is usually in a single core rosin based flux running down the center of the solder wire. Some manufacturers make a multi core flux. In either case the flux melts with the solder and flows onto the joint during the process. Flux does not make up for dirty surfaces or improper heating of the wires. Do not use pipe solder/acid flux with electronics wiring particularly on circuit boards.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-11-2010, 11:11
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Thanks Al. I always learn something new from your posts.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 18-11-2010, 15:09
plnyyanks's Avatar
AKA: Phil Lopreiato
that's what we told the kid... he didn't listen and learned the hard way
Unread 18-11-2010, 16:59
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
I'm very lucky it did not land on my trackpad, it scrapped off and now you can barely even notice that anything happened unless you look very very closely.
Unread 18-11-2010, 17:02
basicxman basicxman is offline
Emily Horsman
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
This is true, mind you in hindsight it kinda gave the laptop and nice design touch.
Unread 18-11-2010, 22:07
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I accidentally got solder on a finished wood surface and you can't tell that it happened unless you are specifically looking for imperfections in the finish.
(I was aiming for a cup of water but that is a story for another day.)
Unread 19-11-2010, 22:58
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I'm always amazed by the number of people at work that have trouble learning not to solder while wearing shorts...
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 20-11-2010, 01:00
Emily Horsman
I'm sure we'd all like to hear that one
I really really shouldn't laugh but...
Unread 20-11-2010, 11:18
It only takes once!
Al
WB9UVJ
www.wildstang.org
Unread 20-11-2010, 12:59
Regarding soldering and fire alarms, (such as those found in schools), am I correct in saying that there is no chance of soldering setting off the fire alarm, because they are activated by heat, not smoke?
Unread 20-11-2010, 13:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You are so not correct. You won't set off a ceiling sprinkler, since those are indeed triggered by heat, but the electric sensors are almost all smoke detectors and will go off.
Smoke detectors are called smoke detectors for a reason. If you are soldering in an area with a smoke detector, you really should be using an exhaust fan.
Unread 20-11-2010, 14:59
Sandy,
People set off smoke detectors all the time if they are working right under the detector and there is no air movement. Most often, the fumes are dissipated quickly enough to prevent false alarms.
Al
WB9UVJ
www.wildstang.org
Soldering Wires to Motors rsegrest Electrical 14 20-02-2010 01:47
Soldering questions Nathan Electrical 18 11-09-2007 21:55
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
Human Player Accidents During 10 Seconds SuperDave General Forum 24 06-04-2003 18:36
