Re: pic: Soldering accidents...
This is true, mind you in hindsight it kinda gave the laptop and nice design touch.
I accidentally got solder on a finished wood surface and you can't tell that it happened unless you are specifically looking for imperfections in the finish.
(I was aiming for a cup of water but that is a story for another day.) |
I'm always amazed by the number of people at work that have trouble learning not to solder while wearing shorts...
![]() I really really shouldn't laugh but... |
It only takes once!
Regarding soldering and fire alarms, (such as those found in schools), am I correct in saying that there is no chance of soldering setting off the fire alarm, because they are activated by heat, not smoke?
Smoke detectors are called smoke detectors for a reason. If you are soldering in an area with a smoke detector, you really should be using an exhaust fan. |
Sandy,
People set off smoke detectors all the time if they are working right under the detector and there is no air movement. Most often, the fumes are dissipated quickly enough to prevent false alarms. |
| Soldering Wires to Motors | rsegrest | Electrical | 14 | 20-02-2010 01:47 |
| Soldering questions | Nathan | Electrical | 18 | 11-09-2007 21:55 |
| Crimping/Soldering | stevex | Electrical | 10 | 01-02-2005 08:32 |
| Human Player Accidents During 10 Seconds | SuperDave | General Forum | 24 | 06-04-2003 18:36 |
