Go to Post "Don't make me call my flying monkeys..." - Joe Johnson [more]
Unread 20-11-2010, 11:18
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: Soldering accidents...
It only takes once!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-11-2010, 12:59
Regarding soldering and fire alarms, (such as those found in schools), am I correct in saying that there is no chance of soldering setting off the fire alarm, because they are activated by heat, not smoke?
Unread 20-11-2010, 13:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You are so not correct. You won't set off a ceiling sprinkler, since those are indeed triggered by heat, but the electric sensors are almost all smoke detectors and will go off.
Smoke detectors are called smoke detectors for a reason. If you are soldering in an area with a smoke detector, you really should be using an exhaust fan.
Unread 20-11-2010, 14:59
Sandy,
People set off smoke detectors all the time if they are working right under the detector and there is no air movement. Most often, the fumes are dissipated quickly enough to prevent false alarms.
Al
WB9UVJ
www.wildstang.org
Soldering Wires to Motors rsegrest Electrical 14 20-02-2010 01:47
Soldering questions Nathan Electrical 18 11-09-2007 21:55
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
Human Player Accidents During 10 Seconds SuperDave General Forum 24 06-04-2003 18:36
