Go to Post No matter what route you choose, it's always a good idea to keep Mike Walker's cell phone on speed dial. - Joe Ross [more]
Unread 20-11-2010, 13:19
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Soldering accidents...
Originally Posted by sanddrag View Post
Regarding soldering and fire alarms, (such as those found in schools), am I correct in saying that there is no chance of soldering setting off the fire alarm, because they are activated by heat, not smoke?
You are so not correct. You won't set off a ceiling sprinkler, since those are indeed triggered by heat, but the electric sensors are almost all smoke detectors and will go off.
Smoke detectors are called smoke detectors for a reason. If you are soldering in an area with a smoke detector, you really should be using an exhaust fan.
Unread 20-11-2010, 14:59
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Sandy,
People set off smoke detectors all the time if they are working right under the detector and there is no air movement. Most often, the fumes are dissipated quickly enough to prevent false alarms.
Al
WB9UVJ
www.wildstang.org
________________________
Soldering Wires to Motors rsegrest Electrical 14 20-02-2010 01:47
Soldering questions Nathan Electrical 18 11-09-2007 21:55
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
Human Player Accidents During 10 Seconds SuperDave General Forum 24 06-04-2003 18:36
