Go to Post If you don't like physical play build a stronger robot. - Koko Ed [more]
Unread 03-12-2010, 08:20
Rob Stehlik's Avatar
FRC #0610 (Coyotes)
Re: pic: Coyobot 10
Yes, we tried approaching the bump at all sorts of angles, and either the robot would tip over, or it would not be able to reach the top of the bump. The latter occurred when we approached the bump at a very slight angle, nearly parallel to it. The 45 degree slopes on the bump were very unforgiving.
The middle wheels were raised and lowered with pneumatics. Raising the wheels made bump crossing much smoother.
pic: The Coyobot 2010 biancs15 Extra Discussion 3 10-11-2010 10:25
610 - Coyobot X Duncan Macdonald Robot Showcase 9 15-03-2009 20:06
pic: Coyobot VIII - Picking up tubes in Waterloo Jonathan Norris Extra Discussion 10 26-03-2007 17:17
pic: 610 Coyobot VIII - Chassis View Jonathan Norris Robot Showcase 1 10-02-2007 17:18
pic: 610 - Coyobot VII Jonathan Norris Robot Showcase 7 23-02-2006 00:13
