Re: pic: 176 Prototype 6WD Rev. 7
If you do use the 80/20 inserts above be sure check them for tightness after every match and use Loctite. They tend to vibrate loose because they don't have the natural "lock washer" properties of things mounted on the sides of the extrusion. These little inserts are very strong and much lighter than L brackets and plates but they can be a pain if they become loose in a hard to access place.
Thank you guys for all of the comments thus far!
This will be our first year building just about anything with 80/20, and to go straight to a frame with it is a little nerve-racking. All other robots we've ever built have been either box or angle aluminum, welded by one of our sponsors. Unfortunately, we don't know if we have that option yet, and that was the impetus for trying some CAD with 80/20. I appreciate the advice on tightening methods, because that's one of the key things we're worried about. Also, thank you guys for the mention of not needing as much support as we've added. I'm going to bring this info to our next meeting and we'll work accordingly. James |
| pic: Articulated 6WD prototype | Tytus Gerrish | Extra Discussion | 16 | 19-01-2010 20:20 |
| pic: Prototype 6WD | kajeevan | Extra Discussion | 26 | 06-07-2009 03:18 |
| pic: FRC1293 Prototype 6wd Chassis | Thermal | Extra Discussion | 16 | 06-01-2009 23:12 |
| pic: 6wd prototype chassis | Collin Buchan | Extra Discussion | 7 | 03-01-2009 10:00 |
| pic: 6wd prototype chassis | Collin Buchan | Extra Discussion | 3 | 02-01-2009 14:14 |
