Go to Post Someone should make FIRST fortune cookies, because I think I just thought of a good one. - artdutra04 [more]
Unread 23-12-2010, 12:12
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: pic: 1918 pneumatic hub concept
Originally Posted by topgun View Post
Wayne,
I am not seeing/understanding the use of shoulder bolts at each end of the axle. Wouldn't it be easier if the axle is essentially a 3/4" round standoff with holes in the end? Then you come in with a 3/8" SHCS from the outside of the frame rails to tighten them down to the standoff/axle. As it is drawn now, if your shoulder bolt bottoms out in the axle before it is tight against the side rail, the axle will be loose.
I love the idea of adding the sprockets without major fabrication/modification to the wheel/hub. Your idea is doable by many less equipped teams.
Also, is this drawn in SolidWorks? Where did you get the model for the wheel?
General question for everyone: The idea of a 6WD with drop center is to enable easier turning, but then aren't you effectively only pushing with 4 wheels when shoving someone?
For the 3/4" axle, the shoulder bolts on the axles could be replaced with bolts. The intent is for the shoulder bolt NOT to bottom out in the axle hole, but rather to mount the axle tightly to the frame. If we do traditional wheels with 1/2" axles on the corners, then a 3/8" shoulder bolt with 5/16-18 threads would be used. This would allow a common frame hole (3/8") and permit interchangeability of axle types.
One of our CAD mentors modeled the hub using AutoCAD. He may have gotten some of the data from the OEM (Wagner ?), but the detailed dimensions on the hub were reverse engineered from the one we bought. The Grainger catalog isn't too specific. This is Grainger p/n 1ZPE1.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
pic: 1918 Quad Drive Device Wayne TenBrink Extra Discussion 13 24-02-2010 11:50
pic: 1918 NC Gears Week 5 - Orthogonal Wayne TenBrink Extra Discussion 5 18-02-2010 20:59
pic: twenty zera niner hub 114Klaatu0x72 Extra Discussion 2 29-01-2009 13:03
pic: 2009 Mecanum Hub - Team 1595 willson.thomas Extra Discussion 23 06-11-2008 17:02
pic: Drivetrain Concept s_forbes Extra Discussion 40 06-11-2008 00:51
