Go to Post I know it's hard to believe, but there actually IS life after FIRST. - jleibs [more]
Unread 26-12-2010, 19:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: pic: off season chassis
Silly John...
That IS the whole chassis!
The game this year is obviously going to be a scooter-like thing!
Unread 26-12-2010, 22:12
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
I tend to agree with JVN's comments, with this addition: Seems to me that by putting the omni's in the middle (presumably dropped the obligatory 1/8"), you lose your resistance to sideways pushes.
"It's NOT Just A Robot Thing!"
Unread 26-12-2010, 22:24
ttldomination's Avatar
Sunny
And are we looking at the outer part of the chassis? I see two sprockets on the middle wheel and one sprocket on each outer wheel, so I'm wondering where the motor goes...
1648: 2013-2014
5283: 2015
Unread 26-12-2010, 22:37
akoscielski3's Avatar
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
Is it realy strong, i would like to do something like this because our normal chassis is extremely heavy, but strong
Unread 26-12-2010, 23:21
MattC9's Avatar
MattC9 MattC9 is offline
I'm guessing the center wheel IS DROPPED so it will function as a normal 6WD chassis. This is so because we all know on most 6WD there are only 4 wheels on the ground so it can rock and turn? right? so the middle wheels act as the turning point so its like a 4WD with omni's in front.
Do i make sense? Because it was a little hard to explain trough the 'net
Unread 26-12-2010, 23:31
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
If the CG is fairly balanced front to back I don't think the traction wheels would get enough grip to greatly affect how the robot turns in place. I suspect you could probably pull some of those fun maneuvers from Lunacy though, like the sideways slides and the backwards-180-forwards whip around. Looks like fun to play with!
Unread 26-12-2010, 23:41
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
This is great I put this up to see what kind of comments i would get .. to clarify things up... we can swap all 3 wheels and I think we were also looking at going for all 6 wheels to be plaction style wheels. we are going to run it on friday soooo we'll see
Unread 27-12-2010, 00:37
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Jun,
Try it in the configuration shown! If nothing else I'm extremely curious how it performs. I don't know if it will perform well (in fact I suspect it won't)... but you'd be my hero if you tried it out and took some video...
I bet if nothing else you could teach some students a cool lesson on drivetrain turning (the video would also be giving me a tool I could use to teach the same things).
-John
Unread 27-12-2010, 01:47
I think this is really cool. Imagine a robot that could shift its CG at will by moving an arm or a weight. You could pivot among whichever axis you chose, if for whatever reason you didn't want to rotate about your center.
Unread 27-12-2010, 08:44
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I am with JVN, give it a spin (pun intended) and shoot some video. I would suspect it would have a very crazy behavior if you had a slightly rear biased CG. Take the 2008 game, where you are trying to do laps. If the weight is rear biased, going into the turn I would suspect the robot to initially push (understeer), but then as the weight shifts to the front, and those wheels grab, it would have crazy snap oversteer. With a lot of practice, you could probably make an "FRC Tokyo Drift" video...
Unread 27-12-2010, 21:56
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Interesting, I think this wheel configuration would be handy in a way. If you ended up pinned, you could shift CG and slip out of it in a lot of cases. My old team designed mechanisms to make the robot 'slippery' in '09 and it worked fantastically. If you can shift CG and need to escape pinning this could be viable.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 29-12-2010, 10:44
Brandon Holley's Avatar
Unless theres some sort of optical illusion going on here, it seems that the omni wheels are smaller than the traction ones. The sprockets on all the wheels appear to be the same size as well, meaning the ground speed of the omni and traction wheels will be different. I still think its worth a shot at trying and showing everyone here your results, just wanted to point that out.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 26-12-2010, 23:33
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
The middle wheel will simply make it so only a front set and middle set or back set and middle set are on the ground at a time. Thus, it's treated like any four wheel drive, except the issue with this 4 wheel drive will be that half of the mass is located beyond the sliding wheel. It certainly appears that resistance to rotation from robot-to-robot contact will be reduced, but this may be intentional (It's an interesting concept that could be explored, IMO).
Attending: MN Duluth Regional
pic: Off-Season Kicker Design rahilm Extra Discussion 22 08-07-2010 19:23
pic: Off Season Proto type joeweber Extra Discussion 6 02-01-2009 12:46
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
