Re: pic: off season chassis
And are we looking at the outer part of the chassis? I see two sprockets on the middle wheel and one sprocket on each outer wheel, so I'm wondering where the motor goes...
Is it realy strong, i would like to do something like this because our normal chassis is extremely heavy, but strong
I'm guessing the center wheel IS DROPPED so it will function as a normal 6WD chassis. This is so because we all know on most 6WD there are only 4 wheels on the ground so it can rock and turn? right? so the middle wheels act as the turning point so its like a 4WD with omni's in front.
Do i make sense? Because it was a little hard to explain trough the 'net |
If the CG is fairly balanced front to back I don't think the traction wheels would get enough grip to greatly affect how the robot turns in place. I suspect you could probably pull some of those fun maneuvers from Lunacy though, like the sideways slides and the backwards-180-forwards whip around. Looks like fun to play with!
This is great
I put this up to see what kind of comments i would get .. to clarify things up... we can swap all 3 wheels and I think we were also looking at going for all 6 wheels to be plaction style wheels. we are going to run it on friday soooo we'll see |
Try it in the configuration shown! If nothing else I'm extremely curious how it performs. I don't know if it will perform well (in fact I suspect it won't)... but you'd be my hero if you tried it out and took some video... I bet if nothing else you could teach some students a cool lesson on drivetrain turning (the video would also be giving me a tool I could use to teach the same things). -John |
I think this is really cool. Imagine a robot that could shift its CG at will by moving an arm or a weight. You could pivot among whichever axis you chose, if for whatever reason you didn't want to rotate about your center.
I am with JVN, give it a spin (pun intended) and shoot some video. I would suspect it would have a very crazy behavior if you had a slightly rear biased CG. Take the 2008 game, where you are trying to do laps. If the weight is rear biased, going into the turn I would suspect the robot to initially push (understeer), but then as the weight shifts to the front, and those wheels grab, it would have crazy snap oversteer. With a lot of practice, you could probably make an "FRC Tokyo Drift" video...
Interesting, I think this wheel configuration would be handy in a way. If you ended up pinned, you could shift CG and slip out of it in a lot of cases. My old team designed mechanisms to make the robot 'slippery' in '09 and it worked fantastically. If you can shift CG and need to escape pinning this could be viable.
#10
Unless theres some sort of optical illusion going on here, it seems that the omni wheels are smaller than the traction ones. The sprockets on all the wheels appear to be the same size as well, meaning the ground speed of the omni and traction wheels will be different. I still think its worth a shot at trying and showing everyone here your results, just wanted to point that out.
-Brando |
#11
If this is the case, the surface velocity of the traction wheels will be faster than the omni wheel, so the omni wheel will experience longitudinal scrubbing (collinear with the omni wheel roller shafts) which may yield weird results when driving or cloud the the expected results of what would happen with equal size OR equal surface velocity wheels. |
#14
The middle wheel will simply make it so only a front set and middle set or back set and middle set are on the ground at a time. Thus, it's treated like any four wheel drive, except the issue with this 4 wheel drive will be that half of the mass is located beyond the sliding wheel. It certainly appears that resistance to rotation from robot-to-robot contact will be reduced, but this may be intentional (It's an interesting concept that could be explored, IMO).
| pic: Off-Season Kicker Design | rahilm | Extra Discussion | 22 | 08-07-2010 19:23 |
| pic: Off Season Proto type | joeweber | Extra Discussion | 6 | 02-01-2009 12:46 |
| pic: Off season project | joeweber | Extra Discussion | 19 | 31-12-2007 22:50 |
| pic: What we do in the off season. (2) | Chuck Glick | Chit-Chat | 7 | 30-05-2006 11:06 |
| pic: 226 Off-Season Prototype Chassis | Matt Reiland | Robot Showcase | 2 | 01-02-2005 19:33 |
