#10
Re: paper: Working with Wires ( striping, crimping, and soldering)
The reason why you're not supposed to tin the wires going into a WAGO power distribution board is because the connector literally pinches the wire and the strands are spread evenly against the contact area in the terminal. If you solder the end of the wire, the individual strands won't be able to spread out against the terminal and will cause a poor and brittle connection.
| Soldering Wires to Motors | rsegrest | Electrical | 14 | 20-02-2010 01:47 |
| Working with spikes and servos in labview | EROCK | Technical Discussion | 2 | 07-01-2009 11:38 |
| Lines and wires | Andrew Blair | 3D Animation and Competition | 1 | 24-05-2005 21:49 |
| Crimping/Soldering | stevex | Electrical | 10 | 01-02-2005 08:32 |
| check this out with soldering | tiffany34990 | Chit-Chat | 1 | 16-08-2004 21:14 |
