Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - rtfgnow [more]
Unread 30-12-2010, 17:31
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: paper: Working with Wires ( striping, crimping, and soldering)
In addition to fork or ring terminals, we may cut a slot in a ring terminal to make it into a hook.
But as pointed out, the Black Jaguars have non-captive screws, so they may be removed without leaving debris. However, I recommend only removing one at a time to avoid replacing the screws to the wrong posts.
Soldering Wires to Motors rsegrest Electrical 14 20-02-2010 01:47
Working with spikes and servos in labview EROCK Technical Discussion 2 07-01-2009 11:38
Lines and wires Andrew Blair 3D Animation and Competition 1 24-05-2005 21:49
Crimping/Soldering stevex Electrical 10 01-02-2005 08:32
check this out with soldering tiffany34990 Chit-Chat 1 16-08-2004 21:14
