Go to Post Advances in STEM are meant to benefit everyone, so even the most basic-level of understanding deserves to be validated and encouraged. - moamomen [more]
Unread 31-12-2010, 01:53
Re: pic: off season chassis
Well that's unexpected. It looks like it's driving exactly like any other drivetrain. Is the omniwheel touching the ground at all? Is it dropped lower than the other wheels, or are all the wheels collinear?
Unread 31-12-2010, 02:22
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
its the dropped 1/8 center. it rocks just a little bit eventually I would like to put on supershifters and run it with that.
Unread 31-12-2010, 02:26
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
But it's on a hard surface. Most any drive will work well on that. Carpet will tell the real tale!
Unread 31-12-2010, 03:15
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
It looks like the front wheel isn't being used at all, like it's acting just as a 4WD with omni's on the front for sliding.
Attending: MN Duluth Regional
Unread 31-12-2010, 04:28
What seemed most odd was that the drive rotated roughly on a dime despite conventional wisdom saying it would have a very odd center of rotation.
Unread 31-12-2010, 09:52
FRC #0234 (Cyber Blue)
Rookie Year: 1942
From the video, it looks like most of the weight is on the back, and the robot is acting like a 4 WD, with the omni's being the "front" wheels. The other "front" wheels do not appear to be in contact with the surface.
When it spins, it is turning around a center somewhere between the back and middle wheels - hard to tell by just doing stop frames on the video.
As others said - try it on carpet. The carpet will give a little and absorb the wheels, whick may allow all 6 to have some surface contact.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 31-12-2010, 10:15
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
It did seem to oversteer a bit and hit the pole in the beginning, but that could be due to lag or driver error.
Unread 31-12-2010, 12:44
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Interesting. Not quite what I expected.
My guess as to what we're seeing:
Is the CG very close to the center? This would put so much weight on the center wheels it would offset the "zero" lateral traction affects of the omni wheels and shift the CG back towards where you'd expect for a "standard" 6WD.
-John
Unread 31-12-2010, 15:42
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Very cool. Thank you so much for the testing and videotaping. Another really cool attribute to the video was the voice explaining what the driver should do as opposed to random driving around.
As far as turning goes, I was impressed that the turing center was so closely loacted to the center of the wheels (most notable at the spin near the end of the clip). I would tend to concur with JVN that maybe most of the weight is on those center wheels.
As fat as my over-steer under-steer comments from before, it would likely take a little more speed for these behaviours to show up. The bot appeared to be traveling at or below 4 ft/s.
Published lateral grip on those wheels is supposed to be around 0.2. I would expect the oversteer understeer stuff to come up when attempting at turn that would have lateral forces around 1/5th a G to 0.5 G. Lateral acceleration is equal to the centripetal force. V^2/r for 4 fps, this would be 16/r = 0.2 to 0.5 or r of 3 to 1 ft.
I will need to review the clip again. From what I remember, most of the turns were done after it had stopped.
Thanks again for trying this.
pic: Off-Season Kicker Design rahilm Extra Discussion 22 08-07-2010 19:23
pic: Off Season Proto type joeweber Extra Discussion 6 02-01-2009 12:46
pic: Off season project joeweber Extra Discussion 19 31-12-2007 22:50
pic: What we do in the off season. (2) Chuck Glick Chit-Chat 7 30-05-2006 11:06
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
