Go to Post Turning is overrated - Allison [more]
Unread 31-12-2010, 21:55
Re: pic: Super Light Chassis System
Originally Posted by Cyberphil View Post
Yes, these are exactly what I am referring to. Our team went away from chains many years ago due to many complications and failures. These could very well be from un-proper tensioning and alignment. I do understand how these problems are solved with this system, but I was just more or less wondering you had ever considered it.
I completely agree. The only reasons we use a directly gear-driven DT is because of the failures in these places. The less room for problems, the less problems in general is our view. And, yes, I understand that there are complications with a direct gear-driven DT also.
Very interesting. Then I have one more question. Why did you name it Team 221 Robotic Systems?
The advantage of this style chain system is that it allows you to run a single frame rail, which saves a good deal of weight alone. The sliding bearing blocks also makes it so machining the rails is far easier, with lower tolerance. A geared system is both heavier and requires more precision.
With proper alignment and tensioning, which is pretty easy, chain failure in #25 chain is a complete non-issue.
pic: super bimba ultra efoote868 Extra Discussion 16 05-02-2008 11:43
Green Light For Vision System Angle & Distance StorminNormin1 Technical Discussion 2 04-02-2007 15:47
pic: Super Brandon Rohith Surampudi Extra Discussion 4 17-06-2006 19:41
pic: Super LAN Barry Bonzack Extra Discussion 10 18-04-2005 20:33
pic: super scooter CD47-Bot Extra Discussion 12 05-08-2004 18:40
