Go to Post DonRotolo used COMMON SENSE. ... ... FIRST/Chief Delphi Community fainted! - PayneTrain [more]
Unread 01-01-2011, 17:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: joystick sensitivity (gain) adjustment
Originally Posted by Roger View Post
...the "left/right" axis is not being changed...General thought of the group is that this gives full turning power always.
Perhaps this is the result of a misunderstanding. Just to be clear: You would still have "full turning power" if you used this sensitivity adjustment for the turn axis.
Look carefully at the figures and the associated narrative. This filter does not reduce the maximum available output. It just changes the response curve to reduce the gain for small commands. The maximum output of the filter is +/-1 regardless of the values selected for the tuning parameters.
What kind of drivetrain are you using, and what type of driver interface?
Joystick Sensitivity furiousgeorge NI LabVIEW 15 04-02-2014 23:10
joystick sensitivity adjustment Ether Programming 3 19-02-2010 00:07
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
