Go to Post Pro: Very easy to build with. Con: HEAVY AS ELEPHANTS - Tetraman [more]
Unread 01-01-2011, 17:35
Re: paper: joystick sensitivity (gain) adjustment
This probably should go in another paper, but it helps handling a lot if you get some speed vs PWM data, and then curve fit it so that you can convert the nonlinear response of the Victors to a nicer linear response. I ended up using a 7th order polynomial last year to do that, and it helped quite a bit.
Joystick Sensitivity furiousgeorge NI LabVIEW 15 04-02-2014 23:10
joystick sensitivity adjustment Ether Programming 3 19-02-2010 00:07
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
