Go to Post This just in: moving sideways still a colossal waste of time. - TheOtherGuy [more]
Unread 02-01-2011, 13:14
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: GUS Team 228's Prototype Sheet Metal 6WD Chassis
Probably a silly question, but what's changed since the last design and why did you make the changes?
We went from single-speed to dog-shifting transmissions, from 5"x2" to 4"x1.5" Colson wheels, from 35p to 25p roller chain, from keyed shafts to hex shafts, changed hole pattern from #10 clearance on 3/4" spacing to alternating #10 clearance and 5/32" (for rivets) on 1/2" spacing, and overall dropped a lot of weight.
Also, the standoffs were modified to have a Delrin sleeve over them. As shown, it was designed for an exact number of even number of 25p roller chain links, so as to eliminate need for a master link. In this state the chain does not contact the standoffs, but as the chain stretches these standoffs can be moved to act as tensioner. Another benefit these standoffs have is it allows us to nest pneumatic accumulators into this (otherwise wasted) space to help keep COG as low as possible:
However, depending on whatever curve ball the game throws us, we may opt out of using these standoffs in lieu of a single sheet metal belly pan and/or sheet metal superstructure parts. If we had access to a live-tooling lathe, I'd combine the sprocket and knurled insert hub for the outer wheels into a single piece, to allow the end shafts to be dead axles.
Art Dutra IV
世上无难事,只怕有心人.
pic: 6WD Sheet Metal kajeevan Extra Discussion 5 03-09-2010 19:02
pic: sheet metal 6WD kajeevan Extra Discussion 23 23-06-2010 10:20
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
