Go to Post Teams that take care of the little things often have much less trouble with the big things! - dtengineering [more]
Unread 02-01-2011, 13:52
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: GUS Team 228's Prototype Sheet Metal 6WD Chassis
Originally Posted by topgun View Post
I drew up a model similar to your 2008 model. One of the questions I had in doing that are what are the pros and cons of putting the chains on opposite sides of the driven center wheel versus having both on the same side? I would think having them on opposite sides of the center wheel would be easier, but then is there a mechanical reason for having them on the same side.
Putting the sprockets on the same side (inside) adds almost an inch to the lateral wheelbase of the robot. This slightly improves turning by moving the angle of the wheel relative to the center of turning closer to perpendicular, which allows for a greater percentage of the wheel's tractive force to be used in the desired direction rather than "wasted".
Looking at this model, why did you go with squares instead of triangles for lightening?
Our sheet metal shop sponsor that fabricates our drive base uses turret-punch machines for their work. Slotted pockets are easy to punch out (punch two or four holes, then use straight punch to connect them). Triangular pockets require a lot of nibbling to make, which slows down the fabrication time. Since their time and work is donated, I like to keep the production time to a minimum.
Edit:
Originally Posted by czeke View Post
What was the total weight, with the upper mechanism ?
There is no upper mechanism on this model, only a drivetrain and base chassis.
Art Dutra IV
世上无难事,只怕有心人.
pic: 6WD Sheet Metal kajeevan Extra Discussion 5 03-09-2010 19:02
pic: sheet metal 6WD kajeevan Extra Discussion 23 23-06-2010 10:20
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
