Go to Post Weird. On a forum where people talk about robots, we have a robot trying to talk to people. - dellagd [more]
Unread 03-01-2011, 17:56
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: paper: 4 wheel independent drive & independent steering ("swerve")
I've developed code for a swerve drive that is based on magnitude and direction from the joystick origin (using halo style controls) and have found that a simple code snippet produces the 180 degree limitation (90 degrees from straight ahead), but certain situations prove this to only work to a limited degree (when the angle moves from 180 to 190, the wheels rotate 170 degrees)
Code:
if(angle>180)//zero is the positive x axis and positive is in the counter clockwise direction
angle-=180;
magnitude*=-1;//magnitude is distance from joystick center, it is always positive unless modified in this line
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Autonomous Independent sparks-1784 NI LabVIEW 16 01-04-2010 09:11
periodic tasks in autonomous independent Ether NI LabVIEW 19 31-03-2010 07:15
Autonomous independent-watchdog errors ewoodring NI LabVIEW 2 20-03-2010 20:19
RC independent of the OI ajsetter Programming 6 30-03-2006 21:44
