Go to Post I got something totally different from my FIRST experience. to me the spirit of FIRST is all about sharing. during the 6 week build period, you share yourself with the other people on your team. at the competition, you share your creation with everyone who watches your 'bot play the game. - George1902 [more]
Unread 03-01-2011, 19:29
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: 4 wheel independent drive & independent steering ("swerve")
Originally Posted by buildmaster5000 View Post
You mentioned that you were working on creating a solution for when the wheels go past an arbitrary 180 degree point. I was proposing the solution that I came up with to your problem. It has it's limitations, but it is simple and reliable.
Thank you for clarifying, Alex. I think you misunderstood what I was saying (which could be partly my fault - I will go back and edit that post to add more explanation).
The joystick inputs are not the problem. If you copy and paste the reference code from, say, Example 1 (Figure 7b) into a text file, edit it to add some window dressing, and compile it and test it, you will see that the reference code as shown already cleanly handles all possible combinations of joystick commands (fwd/rev, strafe, and rotate) and correctly calculates the angles and speeds of each of the four wheels.
The 180 problem I mentioned in the earlier post relates to how to control each wheel's speed and angle, given the correct setpoint and corresponding process variables for each wheel.
The solution to this problem depends on whether the wheels (and sensors) have continuous or limited rotation, and whether the sensors have "dead zones" (gaps). It may also depend on the floor surface and tread material of the wheels, and the power of the steering motors vs the power of the driving motors.
Autonomous Independent sparks-1784 NI LabVIEW 16 01-04-2010 09:11
periodic tasks in autonomous independent Ether NI LabVIEW 19 31-03-2010 07:15
Autonomous independent-watchdog errors ewoodring NI LabVIEW 2 20-03-2010 20:19
RC independent of the OI ajsetter Programming 6 30-03-2006 21:44
