Re: pic: GUS Team 228's Prototype Sheet Metal 6WD Chassis
Originally Posted by Rob Stehlik
Would it be possible to hex broach the Colson wheels directly instead of machining knurled inserts?
Rob- I'll let Art handle the rest of your questions, but I think I can handle this one, as I'm a huge fan of Colson wheels as well.
Colson wheels typically have large inner diameters as you can see in this above image. The hub is a thermoplastic of some sort. My experience with Colson wheels has been nothing short of spectacular....AFTER you get them mounted to a robot. As far as wheels go, they can be a bit tricky to design with. I like Art's knurled insert design because it simplifies the hub design greatly.
In the past I've made hubs that fit into the inner diameter and then have grooves cutout that grab the ribs around the hub of the wheel. They worked well, but are a relatively complex part for just being a wheel hub.
So to answer your question, hex broaching these wheels would be quite difficult knowing that the diameter of the inner hole on the wheel is already quite large. Also, the plastic hub makes for a less than ideal hex broach solution because of the material properties of plastics (shaft will strip out inside hub).
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
