Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 04-01-2011, 11:22
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: paper: joystick sensitivity (gain) adjustment
Originally Posted by Ether
What kind of drivetrain are you using, and what type of driver interface?
It's our 2009 robot with skid steer/tank drive; see this photo. We're using LabVIEW and the standard KOP joysticks and driver station. A single joystick does the driving. The robot drive has the drill-type gear shifter (1st and 2nd gear only; 3rd gear was too fast for Lunacy's floor.)
Adding the second axis to the formula won't be a problem. It was more of "let's get one working first, then add the second." But now that you wrote it out, it makes sense that full power is always possible. We just ran out of time to do the changes.
This was a perfect project as a warm-up, with just enough learning joystick interfacing, sub-vi creation, and math programming, to get done in an hour then debug and change and test after. Adding the different modes and deciding which is "best" will be fun.
There are also two different drivers that we have to program for, and not for the same time. The first (and obvious) is the high school competition driver, who has practice driving with the robot. The second, more unpredictable, driver is the off-season "carnival" driver, a wanna-drive-the robot seven-year-old that throws the joystick all over the place. The former is easy, the latter we can only slow down the action so the robot doesn't crash too much.
Joystick Sensitivity furiousgeorge NI LabVIEW 15 04-02-2014 23:10
joystick sensitivity adjustment Ether Programming 3 19-02-2010 00:07
joystick sensitivity gabrielse Programming 2 08-02-2008 14:52
Joystick sensitivity Philz20 Programming 10 24-01-2008 08:34
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
