Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 04-01-2011, 12:34
Re: pic: 4wd Geared WCD
This setup makes it somewhat difficult to attach bumpers outside of the wheels, particularly with 8" wheels and bumpers that have a very specific 'zone' of placement. The Poofs get away with this by mounting their chain on the inside of the wheel rails, allowing them to mount metal brackets to reach the outside for bumpers -- is it possible to do the same with the gears?
I'm also not sure that the setup would weigh 56 lbs; if it's an issue you may want to double check it, or investigate using other materials for gears (or thinner gears).
GitHub
pic: My First WCD Stephi Rae Extra Discussion 24 23-05-2010 17:19
pic: WCD Chassis Idea Rion Atkinson Extra Discussion 22 21-05-2010 14:17
pic: WCD Sheet Metal Concept Chassis GarrettF2395 Extra Discussion 22 20-05-2010 16:33
pic: gearbox open, geared down 10:1 RMS11 Extra Discussion 4 11-08-2008 08:44
pic: Two Motor, 4WD Matt Krass Extra Discussion 9 13-09-2005 12:56
