Go to Post When I had "shop" back in High School they emphazied safety to the fullest extreme. I'm glad they did, I still have a full set of 7 fingers........ - Stillen [more]
Unread 04-01-2011, 17:05
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: GUS Team 228's Prototype Sheet Metal 6WD Chassis
Originally Posted by Rob Stehlik View Post
How much ground clearance is there?
About an inch; I don't have the exact number, as the files are on another computer at the moment.
But depending on the game, this number can easily be increased. One design we drew up (only drew a 2D side sketch of a chassis rail) had angled bottoms and could clear a 30-degree ramp.
If the game calls for an open front, do you have a plan for joining the frame members mid way?
The same way we did on our 2009 robot: use short end rails and an inner chassis rail further into the chassis.
For the mounting hole pattern on the frame, I'm wondering if you could make them all 1/4" holes. This would allow you to choose either 1/4-20 fasteners, or #10-24, since 1/4" is the drill size required for #10-24 PEM nuts. So if you have a spot where you want to use # 10 screws, just put in a PEM nut.
We hardly ever use 1/4-20 bolts on our FRC robots anymore as #8 or #10 screws work just as well in FRC, but at a fraction of the weight. A #10-32 screw weighs 58% of the same length 1/4-20. By modifying our hole pattern to accept either #10 bolts or 5/32 rivets, we can choose whatever fastener will work better for a particular application.
We also chose #10-32 over #10-24 for two reasons: 1) #10-32 are the screws needed to mount the CIM motor, so we might as well stick to one or the other (nothing is more annoying than picking up a #10 nylock nut and realizing it's the wrong pitch), and 2) the ratio of shank size to pitch of #10-24 screws often causes them to be the second most broken tap at machine shops (#6-32 is the worst).
I like the way you have designed in a series of holes to allow repositioning of the standoffs to serve double duty as chain tensioners. This is much more reliable than using slots to reposition a tensioner. Do you know how much excess chain length would be taken up for each position of the standoff?
It would vary for each standoff, so we didn't calculate it. We did calculate the chain length and design for an exact number of 146 25p links, so any tensioners would depend on how much it stretches.
Plus, we also have a habit of adding in a lot more mounting holes than most parts need. Often times we've found that these extra holes help us out in a pinch when we need to mount a Lexan panel or zip tie wiring to.
Art Dutra IV
世上无难事,只怕有心人.
pic: 6WD Sheet Metal kajeevan Extra Discussion 5 03-09-2010 19:02
pic: sheet metal 6WD kajeevan Extra Discussion 23 23-06-2010 10:20
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
