Re: pic: BCRDrive- everything Nonadrive does, except comparable!
I would recommended the shaft lay parallel to the floor in the omni configuration, so the omni wheels will operate more smoothly.
You could retain the use of pneumatics with a similar mechanism. Also, with the shown mechanism, if the pivot attachment points and the drive hub are not all at the same height, the current setup will result in two different wheel pod angles for each drive hub angle. Do you plan on running a relatively unmodified drive module that 294 usually runs? Last edited by AdamHeard : 06-01-2011 at 19:22. |
| Who's robot does everything? | LightWaves1636 | General Forum | 52 | 30-03-2006 21:52 |
| Not building to do everything?? | TriggsJr | General Forum | 1 | 02-03-2006 09:06 |
| FIRST for everything! | Cpt_Dave_Lister | General Forum | 1 | 22-02-2006 11:13 |
| New To Everything | jmwinston | General Forum | 16 | 03-10-2004 23:08 |
