Go to Post push for what you think is right... just do it in the right way - Andy Baker [more]
Unread 07-01-2011, 01:50
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: pic: Team 2220's Swerve Drive Module
I would suggest #25 chain/sprockets and an AndyMark aluminum sprocket on the wheel. Much lighter and worked great for us in a similar module and reduction.
Unread 07-01-2011, 08:02
Jared Russell's Avatar
Taking a year (mostly) off
I have some concerns about the support of the module itself. It looks like you are using a single COTS "lazy susan" type bearing. My experience is that these sorts of bearings are great when it comes to thrust loads, but they can suffer devastating failures when subjected to lots of torque loads (imagine if your robot is being pushed sideways, or if it turns at a high speed - there's a lot of torque trying to pry your bearing open). Your pivot is located at the top of the module, so the distance between it and the floor acts as a lever arm and amplifies the torque the bearing will experience. We have used this type of bearing on turrets before, and twice we have experienced devastating failures after a big hit where the bearing cracked open.
If you want to get away with a single, high pivot point, I would point you to the www.team221.com Revolution swerve module design - if you read through their product descriptions, you will find the McMaster part # of the bearing they use for module support. Better yet, you can use multiple pivot points (one high and one low) to prevent excessive torquing at the top.
Crab/Swerve Drive Module Attachment Point DinerKid Technical Discussion 5 20-04-2010 12:53
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
pic: Revolution Co-Axial Swerve Module - Team 221 LLC. ajlapp Extra Discussion 10 31-08-2009 15:28
pic: Team 1927's swerve module BlackBird11891 Extra Discussion 7 20-07-2009 09:19
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
