Go to Post On a side note... "Think outside the robot." - I kinda like that. I'll have to use that in a meeting someday.... - Not2B [more]
Unread 07-01-2011, 01:26
FRC #2220
pic: Team 2220's Swerve Drive Chasis
Unread 07-01-2011, 01:31
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: pic: Team 2220's Swerve Drive Chasis
Hey,
Good start! Just a friendly word of warning: a swerve drive takes a LOT of effort to get right, especially on the first try. You WILL spend most of the season fighting this design to get it running right, and to keep it running right. You'll spend so much time fighting with it, your driver won't get to use any of the advantages a swerve drive would provide... I promise you this.
I BEG you to not try to use this design without building it in the pre-season and testing it. If you're putting lots of resources (effort) into your drivetrain you're not going to have as much effort available for your mechanism -- the mechanism is where the magic is, and what makes you successful on the field.
Build a simple, reliable, drivetrain, and spend your engineering on the rest of your robot. You'll be much happier. If the summer comes along and you still want to build a swerve drive, try it then.
If you don't have the resources to prototype it in the summer, you might not want to be attempting it anyways. Again, we all have limited resources during the build season -- spend the ones you have on things that will have the biggest payoff...
$0.02
-John
Unread 07-01-2011, 03:50
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
^^ That. Just that.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 07-01-2011, 07:44
FRC #2220
Thanks for the feedback! We have already prototyped the module and found really no problems with it. The big question mark will be attaching the lateral drive and rotational chains. However, we have the resources to build multiple chassis, so we have some room for error. We also built a failsafe into the design. If we cant drive the modules w/swerve, we can lock their positions and drive standard tank.
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
From the inspector in me, in looking at the base construction, I think 'what a great place for bumpers'. However, if you use this as a design basis, please double and triple check the bumper rules and FRAME PERIMETER definition if it returns this year. If in doubt, please ask the Q&A after kickoff.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 07-01-2011, 12:00
I too like the I beams as use for a frame -- very creative!
From a maintenance standpoint I would make some strategic holes in the I-beams so you can see what's going on inside the modules in the very likely event of a problem.
To solve the frame perimeter issues (based upon previous years' rules), some stiff foam or lightweight plywood would fit nicely into the I-beam rails.
I'll also echo John's sentiments, yet also add to it that programming a crab drive is just as difficult as building it. Hopefully you have very, very talented programmers since they've probably only seen un-optimized or theoretical code.
GitHub
Unread 07-01-2011, 12:24
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
That does appear to be a very nice system you guys have designed, but my question is have you guys figured out how you are going to control it and place the sensors on the wheels? A swerve drive needs the sensors to operate and their positioning can be somewhat tricky and has to be designed for.
As for coding a swerve drive, it took my team about a week straight to perfect our swerve drive code, and at least another week of testing before it was stable enough for the drivers to really use, and during that time the frustrations were high. Be sure to give the base to the programmers at least half way through the build time, because trying to program this with people breathing down your necks is not fun. I speak from personal experience there, our 2009 and then our prototype 2010 robot were both swerve drive.
If you guys would like some examples of swerve code, it isn't very nicely structured, our old code is here:
http://coolhub.imsa.edu/cybercollab/...ming-documents
If you have any questions regarding that code send me a PM and I'll try to help
- Ian McInerney
Lead Programmer, Team 2022
Unread 07-01-2011, 13:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
@Jedward45: Are you planning to rig this up as a crab, or do you plan to have independent drive and steering for all 4 wheels?
Unread 07-01-2011, 14:21
FRC #2220
Yeah, were chaining together via three links the outer rotational sprockets... We still haven't decided on which motors to use for this as our CIMS are all tied up... Were planning on building two drives trains, one to keep behind for programmers.....
Unread 07-01-2011, 15:17
Just remember - mechanical is half the battle. More like a third.
A third is control. Swerve is by no means intuitive to control.
A third is driving practice - swerve is not intuitive to drive no matter how you code it, so your driver needs a lot of time to get used to it for it to really show its advantages.
(Also, the biggest mechanical challenges of swerve come once the module is attached to a full chassis)
Unread 07-01-2011, 15:36
Ether's Avatar
Rookie Year: 1969
I'm not convinced this is true. It seems to me that, with smart enough software, swerve (of the Unicorn variety anyway) should be almost as seamless in its motions as a well-designed mecanum... and without the traction disadvantages of mecanum.
Unread 08-01-2011, 00:52
FRC #2220
Respectfully disagree, we are planing on using gyros to allow absolute direction, so theoretically you could point the joystick to you right, and the robot will go that directions regardless of current orientation.... While this is still just an idea, remember we have a month after the build season to tweak our programming and give drivers practice
Unread 08-01-2011, 01:25
This is based on my experience driving a non-Unicorn chassis, yeah. Moving a tank drive robot with robot-centric controls is trivial. A swerve, absolutely not, especially if you are responsible for module rotation.
My "ideal" swerve would have a field centric "point the modules this way" stick and a robot centric everything else... I think.
Unread 08-01-2011, 03:02
artdutra04's Avatar
VEX Robotics Engineer
Field centric controls on an independent swerve or mecanum drive are probably the most intuitive form of joystick-based driver control there is, especially if you use a three-axis joystick.
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-01-2011, 11:05
Superllama12's Avatar
Superllama12 Superllama12 is offline
Wombaticus
AKA: Brandon Buncher
FRC #0540 (Talon 540)
Team Role: Electrical
Superllama12 is an unknown quantity at this point
That is quite impressive! (hoohoohoo emoticons!!!) From what I understand, Swerve is very difficult to build and use! I hope it works well for you guys!
pic: Team 2220's Swerve Drive Module Jedward45 Extra Discussion 9 08-01-2011 02:00
Team 2338 swerve drive peer review Creator Mat Technical Discussion 13 17-06-2009 17:45
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Team 108 - LEGO swerve drive zander_108 Extra Discussion 8 10-04-2007 22:36
