Go to Post Do you have to think about FIRST when you get up in the morning? - KenWittlief [more]
Unread 10-01-2011, 12:34
mryeagle mryeagle is offline
AKA: Jeff Yeagle
FRC #2229 (ROBOSHOP)
mryeagle is an unknown quantity at this point
Re: pic: BCRDrive- everything Nonadrive does, except comparable!
neat idea..
no reason that the pair of wheels couldnt be mounted to the same output shaft of a toughbox or similar.. (given that it is of sufficient length)
however..
to make it work well I would think that decreasing the size of the high traction wheels JUST ABIT would be beneficial and planning to tilt the mechanism so that the (the high traction wheels) came into contact with the floor) would be of advantage..
i would also suggest that using pneumatics to drive this would be the best plan of attack..
not sure if we will explore this topic further (team 2229) but its neat..
thanks for sharing.
Who's robot does everything? LightWaves1636 General Forum 52 30-03-2006 21:52
Not building to do everything?? TriggsJr General Forum 1 02-03-2006 09:06
FIRST for everything! Cpt_Dave_Lister General Forum 1 22-02-2006 11:13
New To Everything jmwinston General Forum 16 03-10-2004 23:08
