Go to Post Someone want to channel their inner Mark Leon and do the math? - Billfred [more]
Unread 12-01-2011, 13:58
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Smile Re: pic: 2791's Chassis
I've always been an advocate of using smaller diameter wheels for a little better grip on the carpet. You also obtain a little lower CG, which helps on Sat afternoon. Was there a reason that your standoffs appear to be reversed from one side to the other, or just an oversight. are you using belt or chains to drive your front/back wheels? Your rendering is awesome, and is motivating me to learn a 3D modeling program. any suggestions for an old-timer?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
