Go to Post There is a fine line between genius and insanity, watch your step! - Al Skierkiewicz [more]
Unread 12-01-2011, 14:17
Re: pic: 2791's Chassis
Looks like a very solid setup.
If you use the line following sensors, where would you put them?
If we opt to use line followers (I'm thinking an ultrasonic sensor and a gyro for dead-straight tracking is as good as we'll need), we'll probably cut a hole in our electronics board and mount them a little above the bottom of the front of the chassis.
Originally Posted by sdcantrell56 View Post
Id be real careful gearing at 12fps. We did that last year with 4cims and 2fp's and often times our battery was totally dead with around 30 seconds left in the match. We later dropped down to 9.5fps with the 6 motors and it was much better. Just be ready to swap out gearing after testing. Otherwise this looks super awesome!
One of the really cool things about this transmission is the belt reduction - we can adjust with a new belt and output pulley between 9 and 14 FPS without taking up as much space as a chain run would. It also lets us mount our motors in a very compact configuration - the two-motor model is literally 3 inches from the ground.
That being said this is a valid concern - does anyone know how I could predict battery discharge rates using math? I have no idea how to do it.
Originally Posted by Teched3 View Post
I've always been an advocate of using smaller diameter wheels for a little better grip on the carpet. You also obtain a little lower CG, which helps on Sat afternoon. Was there a reason that your standoffs appear to be reversed from one side to the other, or just an oversight. are you using belt or chains to drive your front/back wheels? Your rendering is awesome, and is motivating me to learn a 3D modeling program. any suggestions for an old-timer?
Our drivetrain's CG last year was about 5 inches from the ground.
This year, it's just under an inch and a half.
With the 9 foot tall arm we're working on, that could be pretty important.
