Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 12-01-2011, 21:16
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: pic: Autonomous Aircraft
More specs are here
http://www.me.vt.edu/unmanned/aircraft.html
but basically 94Kg max takeoff weight
Power plant is a twin cylinder Yamaha 2 stroke
ceiling is as high as we tell it to go (we are legally limited on height, basically we want to be able to see it for safety reasons)
The company only lists the speed as about 24km/hr likely limited by the autopilot used.
It is a Yamaha RMAX type G, initially meant for crop dusting, they outfitted them with gps and autopilots for research use.
Basics are here
http://www.barnardmicrosystems.com/L4E_rmax.htm#Item_2
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
