Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
Unread 13-01-2011, 00:11
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: pic: Autonomous Aircraft
Actually this one does pretty much the same thing. Although currently it doesn't deliver the robot through a window, but onto the ground to take soil samples. I do not know when this aircraft was purchased but I think it was previous to 2008.
you can just see the gimbaled camera under the nose, and the pipe on the back landing gear holds cameras used for stereo vision mapping. This was during field trials where the heli flew with a 35lb weight that was lowered 15m and the dynamics of the system recorded as the heli flew around.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
