Re: pic: 1671 Base!
I do believe that frame would be illegal to compete with. The big gap has to be covered by bumper and that looks alot bigger than 8"
Re: pic: 1671 Base!
Yeah you are right the gap is bigger than 8 inches, so it would be illegal in that sense, but this is more of a "programmer's bot" so they can begin programming it, until the lift is completed.
Re: pic: 1671 Base!
That looks.... Hefty. Like, 15 lbs hefty. I assume the production version is going to be lightened significantly over that?
Re: pic: 1671 Base!
Yes the upper structure will be gone plus all the support rails will be made of thinner wall aluminum.
Re: pic: 1671 Base!
So is this pretty much just a practice/programming bot? If so, that's pretty cool.
Re: pic: 1671 Base!
Yeah this way the programmers can begin testing code, and our drivers can start practicing.
Re: pic: 1671 Base!
You'll want to be wary about having your drivers practice too much with a bot that is significantly heavier/different than your competition machine. Although it may drive similarly, you may find that precision movements will have to be retuned. That said, more drive practice is always good.
Re: pic: 1671 Base!
Luckily things still seem to be going good and on track, no surprises yet....haha. See you in Davis everyone! |
