Pneumatic Air Tanks
How many pneumatic ari tanks are we allowed on the robot this yr?
Re: Pneumatic Air Tanks
before anybody says RTM. i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks.
Actually... I'm not going to say read the manual.
I'm going to say, Watch Q&A, because someone asked there already due to it not being specified in the Manual. ![]() |
Actually, I think it's specified just fine in the manual. It's part of the pneumatic system, right? Thus, according to:
IIRC, FIRST Choice had the older (smaller) tanks, and is regarded as an extension of the KOP. As such, you could use those tanks if you wanted to.
So, somebody asked Q&A for specifics. We'll see if they give any response other than " ". |
That particular definition comes from the GDC by way of Bill Miller on Bill's Blog.
It's quite confusing on a number of avenues, like you mentioned. That's why you wait for Q&A. (I'd also be interested in: where do Bill's Blog and Q&A rate in relation to each other and the Updates?) |
unless you have to worry about having enough air to actuate some gigantic 2x24 cylnder. take all accumulators you got 'n' strap 'em on. Worst case you have to take them off and use the one 12" accumulator.
Hmm . . . . no specific storage tank restrictions other than 125 psi operating and 250 psi burst?
![]() Rated at extremely high pressure . . carbon fiber . . 88 ci . . hmm |
#10
well then i would just strap a dive Cylinder to the bot and be done with it.
#11
Why not, I was just looking for a more . . light weight solution.
#12
See Team Update #2. It addresses some of the pneumatics rules.
#13
The Q&A seems to [url=http://forums.usfirst.org/showthread.php?t=16123]confirm that there is no restriction on quantity or type of storage tank. Just be sure to consider the engineering tradeoffs of actually having such a high volume of stored onboard, considering that technically the volume must be filled by the 1.03 cfm compressor even in the pits.
There are tradeoffs, they're just somewhat subtle. |
#14
I've seen a few tanks out there that weigh a bit less, and take up a bit less room than the clippard tanks. That's more what I'm looking at. I KNOW at least one team is going to have a crazy pneumatics setup this year. Last edited by Matt C : 17-01-2011 at 15:08. |
#15
