Did you select "Autonomous Mode" from the Emulation menu? I haven't had any problems with it and it seems to set the bit correctly. Would you mind sending me the code you are using so I can run it through my debugging process?
| RoboEmu 1.11beta1 | rbayer | Programming | 42 | 03-04-2003 13:53 |
| Obscure PBASIC for RoboEmu | rbayer | Programming | 1 | 28-03-2003 23:57 |
| Help testing RoboEmu 1.10 | rbayer | Programming | 26 | 27-01-2003 06:50 |
| Making RoboEmu 1.09 work | rbayer | Programming | 2 | 14-01-2003 00:49 |
| RoboEmu 1.06 (works with XP and 2k) | rbayer | Programming | 4 | 20-10-2002 21:47 |
