Go to Post Ideally, you'll make sure your drive system can handle some Irritating Failures without them becoming Paralyzing Failures. - Billfred [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 27-01-2002, 10:41
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
II. In depth discussion of specific motors
Once people found out the chiaphua motor is in the kit this year, it became the center of discussion. So I will start this section with the Chiaphua motor.
Chiaphua motors (2) specs- #10-32 for the tapped holes
Joe J. posted a lot of info about the Chiaphua motors, which can be found in this thread.
http://www.chiefdelphi.com/forums/sh...&threadid=1457
http://www.chiefdelphi.com/forums/sh...&threadid=1576 (excel spec sheet)
According to Joe J., the specs are: 2.2N-m stall torque. 107Amp stall current, 5500RPM free speed, ~2 Amps free current (all @ 12V).
Which come out to be about 314 Watt Maximum motor power.
Team update 3 came up with a similar chiaphua specs
http://www.usfirst.org/robotics/doc_art3.htm
with a 5600 RPM free speed, ~3.4Amp free current, ~1.8 N-m stall torque, 112.4 Amp Stall current, which come out to be about 280 Watt Maximum motor power. Not much different than Joe J’s spec.
http://www.chiefdelphi.com/forums/sh...&threadid=1992
About Chiaphua mating gear...
You will notice that the output shaft of chiaphua motor have some non standard teeth. It is a 36 Diametral Pitch, 9 tooth, enlarged, 25 degree pressure angle gear AND it is enlarged. The kit came with a gear cluster that can mate with the shaft. It’s a 44 tooth with a 16 tooth next to it, and a ¼” hole in the center. You want to use the 44 tooth side to mesh with Chiaphua’s output shaft, and the 16 tooth side has a 32 DP and a 20 degree pressure angle
http://www.chiefdelphi.com/forums/sh...&threadid=1635
http://www.chiefdelphi.com/forums/sh...&threadid=1487
The material of the gear cluster is a pretty good material, so you can just put it on a ¼” shaft and it will spin fine. Although, just to be save, you can put mount the ¼” shaft in bearings and lubricate the gear
“The gear has some brass content (copper, etc) and is a pretty good bearing.” -Paul Copioli
http://www.chiefdelphi.com/forums/sh...&threadid=1826
“The metal of the gear that mates with the Chiaphua gear is
"FX-2008-90HT copper infiltrated steel heat treated to Ra 68"
A friend looked up the spec. It has a Min Ultimate of 90,000psi.” -Joe J.
http://www.chiefdelphi.com/forums/sh...&threadid=1971
A picture of a quick gearbox for the chiaphua, take a look at how the mating gear go with the chiaphua motor output shaft. It is recommended that you support the gear cluster on both side of the shaft.
“Motor mount screws are 10-32, spaced exactly 2.00" apart
The center "bulge" is .75" in diameter
The centers of each gear (shaft, big gear) is .740" apart.” –Larry Barello
http://64.119.166.94/forums/showthre...&threadid=1571
As for buying a replacement mating gear for chiaphua… The only suggestion so far is to spend around $240 to buy the whole assembly from Atwood. Any better suggestion?
http://www.chiefdelphi.com/forums/sh...&threadid=1984
About gearing the chiaphua down…
http://www.chiefdelphi.com/forums/sh...&threadid=1659
Un-answered questions:
What’s a good way to figure out a best ratio for chiaphua for a fast drive train?
http://www.chiefdelphi.com/forums/sh...&threadid=1764
Is it safe to press gears onto chiaphua pinion?
http://www.chiefdelphi.com/forums/sh...&threadid=2071
Drill motors (3) specs- M4 (3mm length) for the tapped holes
Just motor itself:
0.651 N-m stall torque. 114 Amp stall current, 20003 RPM free speed, ~2.45 Amps free current (all @ 12V).
Which come out to be about 340 Watt Maximum motor power.
With transmission on high gear:
Gear box ratio: 20:1
10 N-m Stall torque, 114 Amp stall current, 1000 RPM free speed, ~2.45 Amps free current (all @ 12V).
Maximum motor power is around 260 Watt. (power reduced by friction/heat/etc of gearbox)
With transmission on low gear:
Gear box ratio: 64:1
29 N-m Stall torque, 114 Amp stall current, 300 RPM free speed, ~2.45 Amps free current (all @ 12V).
Maximum motor power is around 230 Watt. (power reduced by friction/heat/etc of gearbox)
You can only the drill motors that came in the kit of parts… That means a maximum of three drill motors on the robot. Any more drill motors have to be used as replacement parts.
These drill motors have been in the competition for a long time, so most teams shouldn’t have a problem applying them on the robot. Just remember to mount it properly, and keep side loads away from the drill motor output shaft.
Tons on great advices on drill motors in the Nuts4FIRST library @
http://www.nuts4first.net/html/library.html
And there’s the two basic MUST KNOW in Chiefdelphi.com white paper section:
@ http://www.chiefdelphi.com/forums/papers.php?s=
Gear shifting and motor mount by Andy Baker,
Dr. Joe’s drill advice
About drill shaft coupling…
You can buy these drill motor shaft couplings from Small parts to attach a 3/8” shaft to drill’s threaded output shaft. They are pretty reliable, as long as you use them right. Just remember to drill the hole out so the 1/8” dowel can fit (at least some sort of press fitting so the pin don’t fall out) in and lock the coupling in place.
http://www.chiefdelphi.com/forums/sh...&threadid=1885
About speed difference between forward and backward...
People observed an interesting characteristic when using drill motor for the drive train- the drill go faster when spinning forward. It is most noticeable when you mount the two drills outward away from each other (tank drive), causing the motors to spin at different direction. When the robot moves forward, the speed difference cause the robot to turn slightly toward the backward spinning motor. Bottom line is, if you drive train is really fast, you will probably notice the difference… If not, then the robot should go pretty straight. If you can’t mount the motors the same direction, then it is recommended that driver compensate for this instead of limiting voltage to the faster motor. Also, you can use the gyro (Yaw Rate sensors) to sense changes in drive train direction and program the robot to drive straight.
http://www.chiefdelphi.com/forums/sh...&threadid=1600
http://www.chiefdelphi.com/forums/sh...&threadid=1750
About O-ring for drills
If you are not planning to shift gears with drill transmission, and willing to take apart the drill transmission, then you can manufacture these O-ring (or buy pipes from small parts and cut a ring out of them) to fit inside the gearbox to lock it in either high gear or low gear. It is a really reliable way to keep transmission in gear.
http://www.chiefdelphi.com/forums/sh...&threadid=1841
http://www.chiefdelphi.com/forums/sh...&threadid=2027
About buying spare parts…
You should look up a Skil-Bosch service center in your area to buy spare drill motors. The part number for drill motors is 3310k-10.
http://www.chiefdelphi.com/forums/sh...&threadid=2045
Bosch have a homepage @ http://www.boschtools.com/homepage.htm
You should be able to look up service center near you, or where to buy the drills from them.
Fisher price motors (2) specs- M3 (5mm length) for the tapped holes
& Mabuchi motor (1) specs
Turns out Fisher price motors and the Mabuchi motor are identical.
“I will only say that I am 99% sure that the motors are the same.” -Joe J.
http://www.chiefdelphi.com/forums/sh...&threadid=1560
Just motor itself:
0.363 N-m stall torque. 57 Amp stall current, 15000 RPM free speed (all @ 12V).
Which come out to be about 140 Watt Maximum motor power.
With transmission:
Gear box ratio: 147:1
34.7 N-m Stall torque, 57 Amp stall current, 100 RPM free speed (all @ 12V).
Which come out to be about 91 Watt Maximum motor power.
Excel Mabuchi motors spec
http://www.chiefdelphi.com/forums/sh...&threadid=1578
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
Fresh from the forum Ken Leung CD Forum Support 3 15-01-2002 22:22
