Go to Post Large areas of ice in south Georgia is some what of an oxymoron. The best place for ice in south Georgia is in tea. - FrankJ [more]
Unread 28-02-2002, 17:46
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
Inverse Trig
Now that the main robot is done, some of my friends and I have begun to work on a side project involving GPS tracking. We would like to use a PBASIC controller, since we have experience programming it, but we are unsure as to how to program inverse trig functions. Through some internet research we have found some equations that can be used to calculate inverse tangent, but we fear that PBASIC may round the angle measures. Since our robot will drive itself, we feel that we need to be accurate to at least 2-3 decimal places. If anyone has experience with programming inverse trig functions, most importanly inverse tangent, please contact me.
Thanks,
Kostas Skontrianos
scottoulli5@netzero.net
Go Gearheads!!! 102!!!!
Unread 01-03-2002, 18:32
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
I predict that you may have some trouble accomplishing this.
First, the two trig functions available for use in the BASIC stamp, SIN and COS, are tricky in and of themselves. Due to the fact that the BASIC stamp functions on relatively rudimentary binary, it uses completely different units than what you may be used to. Let us draw comparisons between the Stamp's trig and normal trig. While, in most situations, we divide a circle into 2*pi radians, or 360 degrees, neither of these units are of much use in binary. So, the stamp uses a unit call the binary radian (brad). This unit is defined in two ways: there are 255 brads in a circle, and one brad is about 1.406 degrees. In addition, we are used to sin giving us the y component of a point on the unit circle (where the radius of a circle is 1). In PBASIC, however, you will find that sin gives the y component of a point on the 127-unit circle.
Second, you may have trouble interpreting the values returned by trig functions. All unary operators (those that have 1 argument, like square root, sine, absolute value) on the BASIC stamp are performed in the space of a word. This means 16 bits, 2 bytes, or in base-10, 0 to 65535. But this is not nesecarily the value you will find. You have to make sure that the variable you are storing it in is a word.
Third, that word is an unsigned integer. It is in a format that I do not completely understand called the two's complement. Someone else will have to tell you what this means because I really have no idea. It will be a positive integer, but there is some way to tell if it is a negative value.
Hope I have been of some help. You can read about all of this in the PBASIC Programming Manual available from Parallax, Inc. In short, it is possible, but it will be a terribly difficult task.
-Jesse, Team 159
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 01-03-2002, 18:38
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
check out this thread
Brandon Martus
e-mail
Unread 02-03-2002, 17:34
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
In two's complement, the first bit of a number represents the opposite of what it normally would. So, in a two's complement byte, 10000000 would represent -128 instead of +128. All of the other bits count as positive values.
Another example:
10000001 in two's complement is 1 + -128 = -127, while as an unsigned integer it would be 1 + 128 = 129.
Ameya Agaskar
Team 293 alumnus
Unread 04-03-2002, 20:09
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Here is a succesful implementation of the inverse function that was posted earlier by LeoM for this years robot
The function is in the Sidestep program it is taking the joystick and finding the angle for our 4 wheel steering
Thanks again LEO!!!
Unread 13-03-2002, 15:33
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
Matt -
You actually USED it! Great!
How is it working?
I am so glad someone picked up on this - it was just "intellectual exercise" to get me in shape for competition during the fall - but to see someone actually put it in their code! WOW! I'm impressed.
You just never know who will be able to make something useful from your "idle doodling".
Leave it to the FIRST addicts.......
Leo M.
Unread 13-03-2002, 23:27
Using inverse trig is one of the possible ways we plan to guide our GPS bot. If we do decide to use it, it will be a very good implementation of the inverse algorithm. When its all done, I'll make sure to post clips of the bot in action and some of the methods we used to get it to work. Thanks for the inverse suggestions so far.
Inverse Tangent D.Viddy Programming 10 25-01-2003 22:24
Trig archiver 2001 4 23-06-2002 23:14
Return of the Inverse Trig Functions Leo M Programming 3 24-01-2002 08:12
Vector Mathematics in PBASIC Adrian Wong Programming 10 06-12-2001 17:31
