OCCRA
Go to Post Maybe FIRST will just take 148's Tumbleweed and use it as the game piece for next year. - AndyB [more]
CD-Media
Unread 05-18-2018, 12:11 AM
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond reputeCash4587 has a reputation beyond repute
pic: 4587 Swerve 1.0
Unread 05-18-2018, 12:15 AM
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond reputegorrilla has a reputation beyond repute
Re: pic: 4587 Swerve 1.0
Originally Posted by Cash4587 View Post
Can you post a bottom right iso?
What does the connection between the module and mounting plate look like(what are you using for the rotation surface)?
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 05-18-2018, 12:19 AM
gorrilla's Avatar
AKA: adam spears
Also why this versus a coaxial design? You guys always make beautiful robots so im wondering why you'd go for taking up more vertical space instead of lateral space in the frame with a coax design.
Adam Spears
Unread 05-18-2018, 12:39 AM
Cash4587's Avatar
AKA: Cooper Cash
I plan to use a Chinese Silverthin bearing. As far as I can tell it is basically the same bearing but way cheaper. It is a 3.5"ID x 4.0"OD x 0.25"Thick bearing. The triangle shaped pieces are bolted to the 84t steering gear.
https://imgur.com/IiJ6pGi
It makes the module plates Identical when machining them as far as I have thought through it. With a lateral design I would have to mirror some plates and then also machine them differently. I just wanted our first module, which will end up being used for this years game to be simple. With there being plenty of height in this years rules it's not that big of a deal. Also lateral makes your frame taller unless you use a 775pro or miniCIM, which I also don't want to do.
Team 4587: Jersey Voltage - Lead Technical Mentor, Drive Coach
Unread 05-18-2018, 01:02 AM
asid61's Avatar
asid61 asid61 is online now
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Where are you planning on sourcing this Chinese Silverthin? I might have need of one for an offseason project.
Swerve looks solid, although I wouldn't volunteer to machine that bevel gear.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 05-18-2018, 01:25 AM
PatrickW PatrickW is offline
Engineering Mentor
AKA: Patrick Woolfenden
FRC #2910 (Jack in the Bot)
PatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond reputePatrickW has a reputation beyond repute
Very nice looking design. It appears to take a lot of inspiration from my design, which took a lot of inspiration from one of Aren Hill's designs. Please post updates when you get it put together over the off season.
#teamswerve
NerdRage's Avatar
NerdRage NerdRage is offline
Student Captain
AKA: Aaron Fang
FRC #3863 (Pantherbotics)
Team Role: Student
Rookie Year: 2016
NerdRage is a glorious beacon of lightNerdRage is a glorious beacon of lightNerdRage is a glorious beacon of lightNerdRage is a glorious beacon of lightNerdRage is a glorious beacon of light
Good stuff. I like how you're doing the bevel on the wheel, instead of relying on a press fit. Is the shaft of the VP being supported by a bearing on the plate? I'd put one on just to be safe. [Edit: Whoops! Ignore that, I didn't see the picture you posted earlier]
Also, do you have a means of zeroing your modules? With the VP encoder, you're not going to measuring wheel rotation but rather output shaft rotation, meaning that you'll find "zero" falsely multiple times over a single rotation of the wheel.
FIRST Stronghold - LA Regional Judge's Award & Semifinalists, Ventura Regional Semifinalists
FIRST Steamworks - Orange County Quarterfinalists
FIRST Power Up - LA Regional Quarterfinalists, Ventura Regional Semifinalists
Unread 05-18-2018, 01:34 AM
Engineering Mentor
This was the main reason we didn't use the VP integrated encoder on our module this past year. We instead went with a encoder geared 1:1 with the steering of the module. It was very nice to be able to place the robot on the field and not need to make sure the wheels were pointed in the correct general direction or have an addition sensor and need to run a homing routine.
Unread 05-18-2018, 02:03 AM
deltafief deltafief is offline
AKA: David Liu
FRC #1540 (Flaming Chickens)
Rookie Year: 2016
deltafief is an unknown quantity at this point
would a cim coder be good for a swerve like this? It would directly mount on the CIM, I haven't used one before so not quite sure about the accuracy but it seems like that would be a pretty good option because it wouldn't take up space and wouldn't have the problems of the VP integrated one
Unread 05-18-2018, 02:44 AM
Cash4587's Avatar
AKA: Cooper Cash
I'll PM you.
Unread 05-18-2018, 02:46 AM
Cash4587's Avatar
AKA: Cooper Cash
#teamswerve
Yeah, I took a lot of inspiration from Aren's design, and yours, but also many other designs as well.
Unread 05-18-2018, 02:50 AM
Cash4587's Avatar
AKA: Cooper Cash
I plan to use the WCP Hall Effect sensor. Shown here: https://imgur.com/a/fVxFl8y
The only thing I am uncertain about is how this sensor should be mounted/used. I gave it my best guess on what I thought was right.
Unread 05-18-2018, 08:41 AM
samthesnake's Avatar
samthesnake samthesnake is offline
SamD
AKA: Sam Dare
FRC #2767
Rookie Year: 2015
samthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud of
If you do this, you will have to zero the motors before every match. You should look into a 1:1 absolute encoder.
"Perfection is not attainable, but if we chase perfection we can catch excellence." - Vince Lombardi
2015 - 2018 FRC Team 4256, Cyborg Cats
CAD and Strategy lead, drive coach
2019 - Present FRC Team 2767, Stryke Force
Unread 05-18-2018, 09:20 AM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
The Nature Bot - WOOOO!
FRC #1720 (PhyXTGears)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I'll PM you.
If you can send me the source of these cheaper silverthin bearings that would be awesome
Also where are you planning to purchase your bevel gears from?
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: 2013 - 2017 :: Team 1720 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 05-18-2018, 10:22 AM
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond reputeBryce2471 has a reputation beyond repute
+1
FLL Team Future imagineers
2011-????:
FRC Team Mean Machine
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
