OCCRA
Go to Post Stupid programmer question: where does the tread go? - Joel J [more]
CD-Media
Unread 10-02-2018, 02:15 AM
chrisrin chrisrin is offline
FRC #4915 (Spartronics)
Rookie Year: 2016
chrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to beholdchrisrin is a splendid one to behold
How would your team prototype this style intake?
Let's say the game piece is 12" beach balls, and your team wants to try the 2002 team 47-style intake (not sure if they're the first to come up with it). See also attachment.
Questions:
What materials, components, and tools would your team use to prototype this style intake? (wood vs. aluminum tube/versaframe, drills vs. motors+gearboxes, 1/2" hex standard pieces everywhere or something else...?)
What prototyping approach would you take? (variables to test, how to design prototyping to test multiple things at once, approach to testing, etc.)
Context: I think I posted once before... We're trying to up our game this season when it comes to prototyping kit, planning, and approach. This sees like a good example to go through.
Thanks!
Chris
Unread 10-02-2018, 05:41 AM
carpedav000's Avatar
carpedav000 carpedav000 is offline
FF: TSIMFD
AKA: David Carpenter
no team (Lincoln Tech)
Team Role: Mechanical
Rookie Year: 2010
carpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond repute
Re: How would your team prototype this style intake?
I’d honestly prototype it first with some good ol’ pvc pipe, the appropriate poly cord and rollers, and a couple of drills. Relatively inexpensive to do and saves a lot of time.
It isn't shiny enough.
Unread 10-02-2018, 05:44 AM
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
We used this intake in 2012 and had great results with it.
If we would prototype this again we'd use versaframe 1x1 and the versaroller system/tubing. Maybe even use flex wheels instead of rollers?
Also an upgrade to this setup would be to use timing belts and skip the polycord. Definitely recommend not using bevel gears on this setup and running two independent motors (775pros).
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 10-02-2018, 08:05 AM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Would you mind explaining why you say both of these
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 10-02-2018, 08:13 AM
Andrew Schreiber Andrew Schreiber is offline
Petitioning the UN to ban Lythgoe
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
I'd call any of the old 27 mentors and ask them what they found important in their 2008 intake...
https://www.chiefdelphi.com/media/photos/30476
I would also try to use mecanums first to see if I could achieve similar effects lighter/simpler. (Like we did on 125 in 2014) This would likely be a static mockup without motors to see if there was spacing. that would work. Just a shaft through some 2x4s and a mock bumper.
After that, toss together a quick sketch and go to the laser/3d printer to poop out a mix of bearing plugs and a quick structure to hold things in place (or if needed to be bigger than laser, shop bot is an option). Pair of motors in VP's and hook up to some ESCs.
Variables: Speed, grip materials, compression.
How to test multiple things at once - don't. Treat this like an experiment, if you start mixing variables you can't determine impact as well.
I would also consider a simpler 16 style intake given that the team I'm currently working with runs swerve which allows for lining up on pieces in a different way. Relevant because your intake system needs to take into account HOW it will be moving in relation to the game piece, what works for a skid steer may not be the same as for a swerve.
Unread 10-02-2018, 09:02 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
If I had to make this intake, I would probably be in the same boat as RC. Thought process:
* If I had enough old wheels lying around, I'd probably try to do a sanity check using 2x4s and whatever shaft the wheels would spin on first. Just to see if I can space things out a bit and do fewer rollers. (I ball on a budget, sorry not sorry.)
* This intake is going to get beat up being outside the bumpers, so I'm doing either thicker-wall aluminum tubing or polycarbonate tubing on the production version and would want to get to that structure pretty quickly lest it impact other parts of the system. The former, I would source locally. The latter, probably from VEX.
* VersaRoller is wonderful stuff, and it would be my go-to here.
* I agree that it will be easier to have one motor handling the centering and one motor handling the final intake to the robot, partly to avoid getting bevel gears right and partly so that the two can be tuned independently. I can see situations where having them at different speeds will help the intake move faster or avoid jams, which wasn't really an option the last time this kind of intake was common. (In 2012, you couldn't throw around this kind of power without using the BaneBots motors one year removed from the infamous case-shorted ones that left a team dead in the water in Einstein finals. In 2016, the 775pro was brand new. In both cases, you were using motors that probably weren't fully understood if you wanted to get past Fisher-Price/9015/BAG power. These days, we know what the 775pro and RedLine can do.)
* You can make the centering motor spin two ways with a reasonably simple gearbox; the second spur gear will go the other way. While precision is always better, even a sloppy one made on a drill press should serve the purpose here since we're transmitting so little torque most of the time. (You could also use a couple VersaBlock Minis with 40T gears to achieve this.)
* Depending on the number of beach balls on the field and possession limits, I would try to make the compliance come from the ball and maybe the joint this is pivoting out from. $6 a foot for the McMaster tubing that VEX recommends isn't cheap, but it's cheaper than a bunch of compliant wheels and was able to grip fuel just fine. I'd also have a backup plan in case that tubing doesn't do the job, which would probably be compliant wheels or some other material.
* Personally, I'd run polycord on this because I suspect I'll be tuning on this during the season, and polycord is generally cheaper than timing belts.
I'm probably missing some details, but this is my initial spitballing.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
114 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 10-02-2018, 09:10 AM
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Agreed with above, we went cheap on ours and used 2x4s ripped to 1x1 to test the possibility of running this for stronghold. The final version was 1x1x.0625 aluminum tubing, 3d printed rollers, polycord, and some pvc pipe. To get by the gear box idea mentioned above we used a versaplanetary on the motor and ran the polycord belt in a figure 8 to make our rollers run opposite directions.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 10-02-2018, 09:18 AM
Shahil_FRC's Avatar
Shahil_FRC Shahil_FRC is offline
Mentor
FRC #0176 (Aces High)
Shahil_FRC will become famous soon enough
Have you looked into the other style of intake on this concept, ala 971/254 in 2016.
FRC 971 2016 Intake utilizing mecanum wheels to channel the ball towards the center of their robot
https://lh3.googleusercontent.com/-8...25283%2529.jpg
FRC 254 2016 intaking using a full width roller into a ~2" mecanum intake to center the ball
https://media.team254.com/2016/03/86bb0776-2016.jpg
Unread 10-02-2018, 10:55 AM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
The Nature Bot - WOOOO!
FRC #1720 (PhyXTGears)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
There are so many things I'd do differently on 4329's 2016 robot's intake, but thanks for using it as an example
As far as designing this, I did most of the CAD and it was just from looking at images of old intakes like 1323's, 973's and 47's. We didn't really prototype anything, which was a bad idea. If I could redo it now I'd definitely mock up something using some scrap aluminum or wood and figure out the ideal ball compression. Do as much testing as you can ASAP and work those lessons learned into your design.
The Versaroller system was talked about, I'd definitely look at that as well. 4329 used polycarbonate tube as a roller because it was easy to put bearings into the end of it. It worked, but it also flexed a lot due to being 1/16" wall thickness, if I remember correctly. I'd go aluminum tube if I could do that over again. Check out the 1678 video on YouTube for putting rubber tubing over a roller to make it grippy.
Also do not rely on the just the polycord itself to transfer all of the motion between the rollers. We ended up using a timing belt on the first stage from inside the robot's front roller to the 1st roller within the intake, which powered the polycord bands & all the rollers. All off one 775 motor through a versaplanetary gearbox. We had issues with bands slipping, rollers stalling & in turn the ball wouldn't always move.
These types of intakes also require some adjustability to tune them. Our intake was probably too low to the ground, putting too much pressure on the ball. Give yourself some freedom to adjust things to find the sweet spot of compression. That's something we didn't really do with this design and it showed.
Here's a video of our testing too just in case anyone is wondering how it worked: https://youtu.be/YdgZSP8JcoA Let me know if you have any more questions.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: 2013 - 2017 :: Team 1720 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 10-02-2018, 12:30 PM
Andrew_L's Avatar
Andrew_L Andrew_L is offline
Learn to crawl before you ball
AKA: Yo! Champ in the making!
FRC #0299 (Valkyrie Robotics)
Rookie Year: 2011
Andrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond repute
First I would ask you - what are your requirements for this intake? Do you specifically want to build a CD-2002 intake, or do you want to build an intake that can center balls while intaking them?
If it's the former, RC has the best advice. Versatube, versarollers, and flex wheels are the way to go. You could make one of those intakes with almost no machining these days because of WCP / VEXpro parts.
If you just want an intake that can center balls while intaking, look into mecanum wheel intakes. The first I've seen of them is 846 in 2014, but my favorite example is 971 2016. It's much simpler than the CD-2002 intake and has the potential to be lighter, and arguably, more compact. I'm just hoping we see some >4" diameter mecanum wheels released sometime soon.
Unread 10-02-2018, 01:17 PM
Billfred's Avatar
The former is certainly a fun and interesting way to study making something really complex, because that usually opens up new avenues of thought on things.
Neither video you linked to really shows much of the mecanum intake in action; 846 was playing an inbound-to-truss strategy for much of the match, and 971 was practically right on top of the boulders and used their intake (with an omniwheel in the middle) to tap it in. 4901 experimented with a mecanum intake in 2016 and abandoned it after the first event because we couldn't get enough centering effect. Is there some mecanum intake best practice sheet, or is it "fiddle with it until you like what you see"?
Unread 10-02-2018, 01:29 PM
Andrew_L's Avatar
Rookie Year: 2011
Admittedly I didn't get a chance to view the videos too closely while in class, and chose them off of memory of what I thought would be good examples. I'll try finding some better ones to replace those. Having seen both up close, I can confirm that they were just as if not more effective than the CD-2002 intake.
From what I've seen as long as you have the right compression the mecanum wheels work wonders.
Unread 10-04-2018, 12:45 AM
Rookie Year: 2016
Thanks for all the insightful perspectives!
Definitely interested in the simpler design with the mecanums as well. Maybe a good exercise would be to buy a multi-pack of beach balls, split our mechs into two groups, and practice prototyping by building an example of each of these two common centering intakes for the sake of comparison & experience.
The point about the mechanism getting beat up outside bumpers is valid, and it makes me think just starting in aluminum or polycarb tube for structure may be the way to go during prototyping, though the very first prototype could be in wood for the sake of speed.
Fairly balanced support for versarollers, timing belt, polycord - less for compliant wheels given the number (& $$$) that would be needed it seems for this application
The two-motor recommendation a couple of you made makes sense as well.
And plenty of other helpful suggestions as well...
Thanks again. Good luck this year all!
Unread 10-04-2018, 01:57 PM
Ben the Builder's Avatar
Ben the Builder Ben the Builder is offline
AKA: Ben Mosemann
FRC #3303 (Metallic Thunder)
Rookie Year: 2016
Ben the Builder is an unknown quantity at this point
Neither video you linked to really shows much of the mecanum intake in action; 846 was playing an inbound-to-truss strategy for much of the match, and 971 was practically right on top of the boulders and used their intake (with an omniwheel in the middle) to tap it in...
The Robonauts had an intake similar to 971's in 2016, and their reveal video contains several good views of it in action.
https://www.youtube.com/watch?v=sWHwDfpeYjo
  #15   Spotlight this post!
Unread 10-04-2018, 05:22 PM
dkerschbaum's Avatar
dkerschbaum dkerschbaum is offline
FRC #4327 (Q-Branch)
Team Role: Leadership
Rookie Year: 2014
dkerschbaum is an unknown quantity at this point
Probably with PVC pipe, drills, and depending the grip of the balls, either churros (for squishy balls) or pieces of rubber on 1/2 hex shafts (for harder balls).
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
