OCCRA
Go to Post Do not treat Vex and FLL as inferior because they may not get as much exposure as FRC on these boards. Just remember, FLL has seven times more teams than FRC from twenty additional countries. - artdutra04 [more]
CD-Media
  #16   Spotlight this post!
Unread 10-05-2018, 08:57 AM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
The Nature Bot - WOOOO!
FRC #1720 (PhyXTGears)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: How would your team prototype this style intake?
Re: roller intakes, this should be required viewing by everyone for crafting polycord bands or putting rubber tubing over an aluminum roller: https://www.youtube.com/watch?v=fYKsIe-yMrA
I recommend checking out 1678's other resources, tons of good stuff out there.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: 2013 - 2017 :: Team 1720 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #17   Spotlight this post!
Unread 10-17-2018, 01:32 AM
smanrobotics smanrobotics is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 2010
smanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond reputesmanrobotics has a reputation beyond repute
Consider prototyping in stages. For example:
Stage 1) quick mockup - PVC pipes and wood scraps, c-clamps and wood screws, metal scraps where needed for strength. No motors/gears/belts/chains, just manipulate parts by hand. Try multiple concepts.
Stage 2) Add quick and dirty motors/gears/belts/chains, experiment with different speeds and materials and ball compression. Refine as you go.
Stage 3) Make a more robust proto intake and hack it onto an old robot base from a previous year. Drive the mockup around chasing balls to test the pickup in a dynamic environment, try picking up balls trapped in corners, picking up a ball from a clump of balls, etc. Testing on carpet with texture and friction similiar to a tournament playing field.
Here is a link to video of 971 following this process for 2016 intake (segment from 5:17 to 6:38).
Here is a link to 971 robot in a match - view of the intake self centering action at 0:58 and 1:10
  #18   Spotlight this post!
Unread 10-17-2018, 01:36 AM
Andrew_L's Avatar
Andrew_L Andrew_L is offline
Learn to crawl before you ball
AKA: Yo! Champ in the making!
FRC #0299 (Valkyrie Robotics)
Rookie Year: 2011
Andrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond repute
My man Steve coming in clutch with the science! Mods can close this thread, the best answer has just been given.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
